Etching Glass with the Dremel 4000
Before
Loading.. -
After
Loading..
Project Summary
The Dremel 4000 high-speed rotary tool offers a variety of options for etching designs into glass. When paired with the detailer's grip attachment model A577 it provides users precise fingertip control for detailed work. In this project we used a diamond point bit #7103 with a three-thirty-seconds inch collet #481.?? After you've selected and traced your pattern, connected the Detailer???s Grip attachment, and set your tool to a speed between 15,000 and 25,000 rpm, you???re ready to begin etching.Etching glass requires some practice. We recommend you experiment on less expensive glass objects first. With the Dremel 4000 and the Detailers Grip you can achieve a great level of detail for added effects and intricate designs.After the pattern is complete, wipe the area clean with a cloth and you're done.Here are some more thoughts on etching glass.Smaller bits and cutters require the use of smaller collets. Make sure to use the correct collet for the accessory you choose.Tungsten carbide bits can be costly. We suggest you practice etching first with silicon carbide stones to become familiar with the process before advancing to tungsten carbide.Diamond points provide a very fine line. Tungsten carbide cutters provide a sharper, more aggressive line. Silicon carbide stones provide a fuller but softer line, and they are great for smoothing rough edges. In combination, the different bits can be used to create the right look for any piece.These bits are not intended for drilling glass.For tips, tricks, and safety info consult your tool's manual
