I just finished "re-modeling" my garage...before I touched it it had just taped drywall and concrete block walls, unfinished cement floor, wires for the garage door openers hanging all over the place, holes in all the walls/ceiling. It was a typical, dirty, dark garage.
I painted the concrete walls with Behr waterproof masonry paint and the rest of the walls and ceiling with the same color behr paint (twilight gray-to lighten it up).
I did the floor with Behr 1 Part Epoxy, which, takes forever to prep for, but the result is worth it. You first need to sweep very good, then clean/de-grease and etch the concrete using a floor cleaner rented from HD...then let it dry. I let it dry for about 2 weeks. Once I was sure the concrete was dry, I applied 2 coats of concrete bonding primer. I let that dry for about 24 hours, and I was finally ready for the paint. The paint goes on easy, one coat was plenty. I sprinlled in some color flakes and let it dry 24hrs. I then began my first of three coates of low gloss sealer. The finished result was very pleasing...
I then re-installed my Gladiator Garage Works 8 foot work bench, wall cabinet and tool chest as well as a second wall cabinet and large gearbox that I purchased for my new garage... I also built a wooden cabinet around the circuit breakers and painted it gray along with the framing for the garage doors, a beam in the middle and the door into the house. I finished with gray vinyl trim molding around the walls.
I also mounted the bikes, a shop Vac and misc. brooms, saw horse, etc... on the wall(s).
All of the wires from the garage door openers were hanging down and sloppy (prev. owner) so I disconected everything and ran it through PVC for a cleaner look.
I then added a few finishing touches, Bud Light neon clock, pictures (NE Patriots Cheerleaders), and mounted my novelty license plate collection as well as a few other items...
Moving all of my furniture/tools out of the garage was a big project in itself, and I lost my basement(i.e. Gym) for about a month and a half, but the end result is a very clean, organized garage that is "my" place...
