cancel
Find Qualified
Local Contractors
Select Service:
Enter Zip:
community forums
Close Help
Help FAQ
Creating a Project:
  • Just go here and follow the simple instructions.
Updating/Modifying a Project:
  • You have a bunch of editing options available on your project page.
  • Just look for the edit icons. Edit Icon Click on them to change some text or swap out an image.
Uploading/Changing Photos:
  • You can Upload your own photos to to your project page. Images will be scaled down to 550x500 pixels.
  • Click change photo next to an image to swap it out for a new one.
  • Click remove photo next to an image to permanently delete that photo from your page.
  • Click Add a Photo add extra photos to your project page.
Reporting Inappropriate Content:
  • Click Flag as inappropriate and an email will be sent to our editing staff who will review the page immediately.
  • Just click report this next to a comment to let our editors know a review is needed.
Close Helpclose Help
Two Room Addition
  • Currently2.92/5 Stars
  • 1
  • 2
  • 3
  • 4
  • 5
out of 154 votes
Created: Apr 12, 2008 by SKHK1
Email Page   Print Page
Before
Before Photo
After
After Photo
Project Summary
With six people in the family we needed extra space. Once we made the decision to add on we started making phone calls. The original estimates were 35K - 40K, that was out of our budget. We then started getting material estimates with us doing as much of the work as possible. Our estimate was now about 15K which we could handle.
It took us about 5 month to complete, my wife and I did all the work with a few execptions. If you had not seen the house before you would never know that we added the addition.
Project Journal
Prepration
We were adding to the side of the house and luckly there was no utilities on this side of the house. We removed all the siding from the side and set it aside for later use. We also had to remove the fence (before photo taken when first moved in before fence was added) so the cement truck could make it back.
Slab
After several calls we found a local cement company that would pour the foundation at a reasonable cost. They did the site prep work and poured the 24' X 24' slab.
Framing & Roofing
Over the next two month my wife and I did all the framing, roofing and installed the windows.
Siding
I took a piece of the siding taken down earlier to several siding companies until I found a match. We only needed to purchase enough to do the front of the addition. Since the addition fit under the roofline of the existing house and was 4 feet narrower, the siding that was taken down earlier was enough to cover the end. For the back we took down the siding that was on the front and used it for the back of the addition. We then put a faux brick siding on the front.
HVAC & Electrical
Due to local building code I was not allowed to do the HVAC and electrical work. To keep cost to a miminun I installed all the outlets, fixtures, and junction boxes. I then pulled four wires from the main circuit breaker box in the garage on the far side of the house to the addition. The electrician then came in and simply made the connections. So that I would not have to deal with gas lines, we added a heat pump unit for the addion. We had two rooms of the exisiting house taken off the existing system added to the new heat pump system to reduce the stain on the existing HVAC system.
member comments
or Register to leave a comment
Tags for this project
Budget & Materials
Budget:
$15000
Materials:
    More Photos
    Alternate Photo 1Alternate Photo 2Alternate Photo 3Alternate Photo 4
    More Projects from SKHK1
