Honeywell H46E1013 humidistat with a/c
02-18-12, 11:12 AM #1
- Join Date
- Mar 2001
- State:
- CT
- Posts
- 464
We have a Honeywell H46E1013 humidistat that is connected to our condo a/c (central) unit. How I understand it is that if the humidity rises above the set point, no matter what the thermostat is set at, the A/c should come on. Is that correct?
I turned the humidistat down and heard a click, but a/c did not come on. I was thinking of taking it out and shorting the two wires that are attached to the humidistat. Then the a/c should start.
Is that correct?
Thanks.
Dave
02-18-12, 11:37 AM #2
- Join Date
- Mar 2001
- State:
- CT
- Posts
- 464
So, the plot thickens.....I checked it out, and the humidistat is wired in series with our thermostat. So it acts to shut off the a/c when I turn it higher.
How would I set this when we are away so we do not get mold? We are away for months at a time in the summer.
I have been setting it to 65% and thermostat to 82. What would be the proper setting to prevent issues with mold? As I understand it, for the a/c to work, both the humidistat and thermostat would have to be calling for the a/c to run.
Thanks again.
02-18-12, 03:18 PM #3
you would set the thermostat as low as you would like the temperature to be on cooling. Next you would set the humidistat where you would like the humidity to stay.
With the humidistat set at 65% and stat at 82 both the temp would have to be above 82 and the humidity would have to be above 65% inorder for the a/c to run.
You want the humidity around 50 - 60%
it is what it is
02-18-12, 04:39 PM #4
- Join Date
- Mar 2001
- State:
- CT
- Posts
- 464
I was thinking about when we are not here (in FL) in the summer. I was going to set humidistat to 65% and a/c thermostat to 80. Do you think that would be adequate to prevent mold formation? Or should I set thermostat lower? That way, only humidistat would have to turn on a/c, sine they are wired in series.
02-18-12, 05:14 PM #5
I would think would be ok, or maybe lower the humidistat more.
it is what it is
02-19-12, 04:04 AM #6
- Join Date
- Mar 2001
- State:
- CT
- Posts
- 464
Thanks very much for your advice.
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
