36 volt E Z go electrical question
Donavon's Avatar
WI
05-17-17, 06:08 AM   #1 (permalink)
Can I hook any 36 volt quality charger to the cart by attaching the 2 prong plug from the old charger to the positive and negative leads on a quality new 36 volt charger? It is a new variable voltage charger by Shumacher.
Pilot Dane's Avatar
NC
05-17-17, 09:32 AM   #2 (permalink)
I assume your cart is older and has lead acid batteries in which case you can charge it with whatever. Some chargers are better than others but I would pick one good for deep cycle batteries and is able to perform desulfation. I would also get a dedicated 36v charger or one that at least allows you to manually select the voltage.
