Login to DoItYourself
Forgot username or password?
Or Login with Facebook
Don't Have an account? Sign Up Today
do it yourself
  • How-Tos
  • Your Projects
  • Forums
search
Hi Unregistered | Logout Login Sign Up
  • Forum
    • New Posts
    • Today's Posts
    • FAQ
    • Calendar
    • Community
      • Member List
    • Forum Actions
      • Mark Forums Read
    • Quick Links
      • View Site Leaders
  • Advanced Search
  • Home
  • Forum
  • Interior Improvement Center
  • Basements, Attics and Crawl Spaces
  • Insulating my basement. Is my plan too simple?
The Facebook Platform
Login | FAQ
+ Reply to Thread
Results 1 to 5 of 5
  • LinkBack
    • LinkBack URL LinkBack URL
    • About LinkBacks About LinkBacks
  • Thread Tools
    • Show Printable Version
  • Search Thread
      Advanced Search
  • Display
    • Switch to Hybrid Mode
    • Switch to Threaded Mode
  1. 11-16-05, 05:42 PM #1
    Don.1936 Visiting Guest
    Question one. How far down?
    I live in a comfortable 60-year-old house with an undeveloped basement used mainly for storage. I don’t intend to develop it, but I’d definitely like to put a little insulation in place around the inside of the foundation in order to save some energy. (We don’t explicitly heat our basement, but enough heat escapes from the ducting, hot water heater, etc., to make it tolerable down there in the winter.) The basement has 7.5 foot painted (latex) concrete walls (in excellent condition) that rise about three feet above ground level, with the floor joists embedded in the concrete at the top. I haven’t yet determined how far down I should take the insulation. I’ve been looking around this forum, but haven’t yet found an answer to this question (for an undeveloped, unheated basement.) Any suggestions? (I suspect it’s good to not insulate it all the way down, so as to get the benefit of some cooling in the summer. )
    Question Two. What’s wrong with this solution?
    The southern Alberta climate is pretty dry, summer and winter, and I’ve never had any sign of moisture in my basement (except when my hot water heater leaked on me). Luckily, we have sandy soil and excellent drainage. Anyway, I want to do the insulation as simply as possible and suitable for a basement that will only be used for storage. (I’d like to do a neat job, however.) . . . . . Well, here’s my plan. I’m going to buy some rigid R5 pink foam board and use silicon or some such thing to glue it to the walls from the top down to the desired depth (see question one). Then I’d like to glue some painted 1/8” thick (?) wood paneling over it to provide a protective surface. I’ll cover the joints with 3/4” molding. I don’t plan to use a vapor barrier because our climate is so dry and we’ve never had a problem with moisture. In fact, we’d welcome a little more moisture in our house, especially in the winter. So how does this sound? Any suggestions as to what type of adhesive I should use, if I go ahead with this?
    It may be evident from the preceding that I’m not really too experienced with home improvement projects, so any advice to steer me in the right direction would be very welcome. Thanks in advance.
  2. Sponsored Links
  3. 11-16-05, 06:55 PM #2
    Concretemasonry's Avatar
    Concretemasonry
    Concretemasonry is offline Member
    Join Date
    Mar 2005
    State
    MN
    Posts
    6,073
    You have hit on several good points that most people miss because they are micro-managing basement climate control.
    1. You are smart enough to recognize the benefits of not covering the entire wall with insulation and getting the benefits of the thermal mass or "heat sink" during the AC season. The soil is a wonderful moderator - at 5 feet down, it possibly 50 degrees warmer than outside air in the winter and is 30 or 40 degrees cooler than the outside air in the summer. You certainly can have some summer heat in Alberta. It really doesn't make sense to totally insulate the wall.
    There are some Canadian stanards that suggest insulating the upper portion of the wall. While there is no magic line drawn on the concrete near or slighlty below grade, it makes sense. I can find no strong technical reason for the standard (I have search hard). It is based on an economic study of insulation few years ago.
    I think the partial insulation makes more sense than the "cacoon" system where you are preventing the heat generated inside the house from being naturally moderated. This is especially true in dry climates.
    2. Gluing rigid extruded styrofoam to the walls has worked very well many people over the years. You could insulate the upper portion with the foam. You could use strips as spacers to support the paneling.
    A true carpenter would not appreciate this approach, as would those who want a basement remodeled to a level that exceeds the upstairs finished by a builder. This concept could also be responsible for a few of the academic types shooting it out over scientific difference of opinions.
    Keep in mind you are improving a storage area and "building a piano".
    Dick
  4. 11-17-05, 08:09 AM #3
    em69
    em69 is offline Member
    Join Date
    Jul 2005
    Posts
    857
    See following link which explains how far down to insulate:
    http://www.joneakes.com/cgi-bin/getd...ls.cgi?id=1545
    Go info why not to leave an air space:
    http://www.joneakes.com/cgi-bin/getd...als.cgi?id=743
    The first paragraph explains how to properly apply the foam board to the concrete wall to avoid an air space:
    There is so much good information on this site, plus you could also contact CMHC and the NRC for information.
  5. 11-17-05, 11:48 AM #4
    Very helpful. Thank you. Don.
  6. 11-21-05, 10:46 AM #5
    Konrad Fischer Visiting Guest
    No 'modern' Insulation!
    Because it can not stop IR-Radiation, which brings out about 99% of the warmth. Only solid construction materials like wood can insulate warmth losses in reality. In Germany we have a lot of tests about that topic, besides our building industry and their slaves in government applaud for polystyrene and mineral wooll etc.
    So I would be happy with your good old house, saving costs and the risks of dampness and mold. More information you will find on
    www.xxxxxxxxxxxxxx-info.de/7mold.htm
    and
    www.xxxxxxxxxxxxxxxx-info.de/2auffen.htm
    Good luck!
    Konrad
    >>>>Forum Monitors Notes:
    The thread has been edited.
    Advertisements within the forum topics or within replies posted or within personal signatures, personal web sites or including email addresses within replies or signatures is not allowed on this web site. Surveys, Ads, Advertisements, Solicitations to market products, services or to hire person(s) to perform work is also not allowed in any forum topics.
    Posting email addresses for others to contact to obtain information or to market products or directing anyone to personal web sites which can market products or solicit services, etc are not allowed. There Are No Exceptions.
    Members posting any of the above or similar, anywhere on the web site are doing so in violations to the policy and are subjected to suspension or banning.
    No topics are to be used for personal gain using any method. Allowing any of the above degrades the entire web site for all concerned parties.
    Read The Rules Here:
    http://forum.doityourself.com/announcement.php?f=2&announcementid=113
    http://forum.doityourself.com/announcement.php?f=2&announcementid=114
    Sincerely, Robert Horning.
    Web Site Administrator.
    Sharp Advice. Web Site Host, Forums Monitor & Multiple Topics Moderator.
+ Reply to Thread
« Previous Thread | Next Thread »
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
  • BB code is On
  • Smilies are On
  • [IMG] code is On
  • [VIDEO] code is On
  • HTML code is Off
  • Trackbacks are On
  • Pingbacks are On
  • Refbacks are On
Forum Rules
  • Newsletter Sign-Up
    Signup
  • Find a Professional
  • Follow @DoItYourselfcom
  • Related Ads
DoItYourself.com®, founded in 1995, is the leading independent home improvement and repair website. We welcome your comments and suggestions. All information is provided "AS IS." Website operating problems contact Webmaster. Questions of a Do It Yourself nature should be submitted to our "DoItYourself.com Community Forums". Copyright © 1995-2014 DoItYourself.com Inc. All rights reserved. You may freely link to this site, and use it for non-commercial use subject to our terms of use. View our Privacy Policy here.
RSS feed Advertise Find a Contractor Interactive How-to's About Us Terms of Use Privacy Policy Cookie Policy Site Map
DoItYourself.com is an INTERNET BRANDS company.
  • Contact Us
  • DoItYourself.com
  • Mobile Site
  • Privacy Statement
  • Top
Powered by vBulletin™ Version 4.2.2 Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
