Mira/Waffle Drain and Radon sealing
Hello,
Does anyone have experience on how to seal the Mira drain which comes up about 4" on the basement cinder block wall? I need to add a radon abatement system and need to seal air leakage. Thinking there must be plastic cap molding or something, but can't find anything...
1st make certain there are no wall leaks which would run down the wall & enter your sub-floor system behind the miradrain if nothing, use siliconized caulk - that's what we do if you can't live w/that look, suppose you could fasten some z-channel over the miradrain
