Finishing around outswing door in basement knee wall.
I put in an out-swing door last year and now I'm working on finishing the basement.
I have a couple questions about framing / preparing for Sheetrock around this door.
Around the inside concrete opening, I'm not sure what I can do to apply Sheetrock here. I was going to put 1/2 foam board here to complete the air seal, but if I do that I'm left with about 3/4" between the foam and edge of the door jamb.
Any suggestions?
Then on each side of the door I think I've decided to install cabinets or shelves above the knee wall, instead of just adding the typical ledge shelf.
I was thinking about framing it out like the image below, adding boards where needed to allow Sheetrock to be attached. (Yellow would be new construction)
Is this a sound plan or are there things I'm overlooking?
Thanks!
Any suggestions?
Thanks!
Sort of.
Still missing the jamb extentions around the door.
In your area there should have been 2 X 6's and at least R19 insulation in those walls.
That looks good. To trim the door out, you will just add an extension jamb onto the existing jamb, so that the face of your new extension jamb will be flush with the drywall. Pocket screws are a good way to attach the new jamb to the door. Your pocket screws will be hidden on the back side of the jamb. Then after drywall, add some casing.
Originally Posted by joecaption
Sort of.
Instead of using my foam board between the wall and jamb, should I be using sill plate gasket roll and / or use treated lumber here?
Face of jamb flush with drywall. I would omit the foam behind the jamb and just leave a space by using 3/4" material. After it is installed you can spray foam the gap.
Finally making some progress on this.
Turns out a PT 2x10 flush against the concrete cut-out will put it even with the inside of the door jamb, and put it even with the 1/2" drywall on the new wall. And give me enough room to construct a threshold ramp in-between.
Looks good. If you look at the original pictures, you didn't have a super wall built, and that was the reason for suggesting jamb extensions to the edge of the sheetrock. You're good. Not paintable right away, but good.
Yeah thats where I suggested using 3/4" thick stock (something nice since its trim) for the jamb with foam behind. As long as you're happy with it.
