How to clean acrylic sealed concrete?
ws669's Avatar
TX
04-19-17, 01:51 PM   #1 (permalink)
I acid stained and used 2 coats of an acrylic solvent sealer on my concrete patio. Looked very good until it rained and my dog got mud prints all over the patio. I thought since it was sealed I would just be able to hose off the dirt. It looks real good when I get it wet, but when it dries the mud prints are still there. I ended up using some soap and a mild scrub brush and it got the prints off but it left some soap residue behind, and it also took a while. It is more of a pain then just having unsealed concrete. I thought sealing would make it easier to clean. Are there any easier ways to clean sealed concrete?
Thank you,
stickshift's Avatar
WI
04-19-17, 02:09 PM   #2 (permalink)
Yep, you turned a maintenance free product into one now requiring maintenance.
marksr's Avatar
TN
04-19-17, 02:41 PM   #3 (permalink)
You'll have to train the dog to wipe his muddy feet
It shouldn't be a big deal to scrub with detergent and rinse off. Part of the price you pay for stained/sealed concrete. On the bright side you shouldn't get any deep stains like you would with unsealed concrete.
retired painter/contractor avid DIYer
John_7878's Avatar
CANADA
04-20-17, 11:42 PM   #4 (permalink)
Sealed concrete is non-porous, it resists most stains and is, therefore, exceptionally easy to clean and maintain. Sweep your concrete floor well. If you have a high-powered vacuum cleaner that will suck up the dirt, you can even use that instead.Use a dust mop after sweeping. This will remove small particles the broom (or vacuum) might have missed.
Mix warm water and a few drops of a mild detergent (dish detergent or a mild laundry detergent) in your mop bucket. Mop the floor with this solution. You can use any kind of mop you choose--standard or sponge. If concrete has greasy food stains, pour a little extra detergent (preferably dish detergent, in this case) on the stains and scrub it with the mop. You can use a soft-bristled brush or scrub pad to loosen stuck-on grime from the floor, if necessary.
