how can I remover primer from a stair bannister
02-17-09, 04:40 PM #1
- Join Date
- Feb 2009
- Posts
- 2
My daughter accidently primed a bannister that should have been stained. Can this thin layer of primer be removed and the wood then stained?
02-17-09, 07:40 PM #2
- Join Date
- Feb 2009
- Posts
- 11
I think the only real way to go about doing this would be to sand it down. And if it's the whole banister..you might be in for a lot of work.
02-18-09, 03:35 AM #3
- Join Date
- Feb 2009
- Posts
- 2
thanks, I didn't know if a stripper would work or not, sounds like a sanding is the way to go
02-18-09, 01:35 PM #4
- Join Date
- Mar 2005
- State:
- TN
- Posts
- 21,200
Welcome to the forums dwspringer1!
Strippers don't always work well on a thin coat of paint/primer. If you have trouble removing it all with sanding, you might try scrubbing the wood with lacquer thinner or liquid deglosser - be sure you don't let any solvent drip and sit on any paint or stain as it might harm the looks of the finish. After the solvent dries, sand some more
retired painter/contractor
avid DIYer
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
