Identify this wood?!
I'm having trouble posting a photo. Is there someone I can email a photo to that will help me?
Welcome to the forums!
See How To Put Pictures In Your Post and How To Include Pictures.
We look forward to seeing them.
Your profile indicates you're in Australia? For those of us here in the USA, it might mean that the exact species of wood might baffle us. What's ordinary there might be exotic here! Good luck posting the pics.
http://img209.imageshack.us/img209/6733/imagekpx.jpg
http://img208.imageshack.us/img208/1296/imagehss.jpg
http://img248.imageshack.us/img248/6427/imagesomc.jpg
Thanks for the help mate fingers crossed it worked
Pictures are fine. Only thing I would request, if possible is a pix of the end grain. It resembles our fir or spruce, but an end grain pix may help narrow it down. Is this on a table?
Yeah this is large dining table. It's been handed down over generations so I'm looking into restoring it a little but need to know what that wood is!
Thanks for your reply. I can definitely get more pictures but what exactly am I taking it of? Sorry i tried to google the end grain thing but I'm left a little confused lol.
thanks for your help
Ok so here's a pic of the edge of the table. It doesn't really look like the pictures above but the word kind of curves down on the side.
Hope this is what u needed
That doesn't look like end grain to me. Best guess from me is pine but I'm not the best one at this kind of stuff on the site so hang tight for the others.
In the meantime, can you get a picture without so much flash reflection in it?
It is definitely a soft wood such as pine, spruce, fir, etc. Clear, however. The table won't show end grain, since the edges are either breadboarded or finished, so that's OK. How much refinishing does it need? Is it right on top? I doubt there is a stain on it, but if so, a light one.
Thanks guys!!
There are a few scratches on top i want to see if i can sand back a little and stain the whole table (It appears to have a light staining to it). so now to do some research on fixing up softwoods!
Thanks again and i appreciate your help! I didn't even know where to start before looking at this site probably would've messed up quite a nice table lol.
I won't be starting this overnight as I want to know exactly what I'm doing before i start, so I'll have a look around the forums for any threads to help me in the next step. If u have any helpful links feel free to help some more
Stain is only effective over raw wood. It's possible that you might just be able to sand the top and apply another coat of poly. It's possible the wood doesn't have a stain - oil base poly will deepen the colors naturally in the wood and also ambers some as it ages. If you want a darker stain you have 2 choices; remove all of the existing finish [chemical stripper then sanding] or apply a tinted poly like Minwax's PolyShades.
Mark beat me to it but as soon as I read your last response I had the same thought going through my head - stain works by being absorbed into wood so there can't be anything on the surface already. You could sand the top and then add some oil based polyurethane to deepen the color or strip it back to wood and start over. I don't know that you have pine per se but seems to be something similar and pine is kind of tough to stain so my thought would be to see what I could do with just the poly first.
OK, so it works with drying finishes like lacquer but not curing ones like poly?
I wonder if it's lacquer?
#21
What about these pictures makes you guys think it is a softwood? Truthfully, I can't really tell what it is in the picture. Being half way around the world in an area that has completely different wood supplies doesn't make it easy.
blair777, do you know what woods are commonly used for furniture in Australia?
#22
I want to say it is maple since it is a older table. That grain to me is too tight to be pine or fur. Also the way the color glows in certain areas, and the small knots, makes me think it is maple.
Maybe a picture of the bottom side of the table would also be helpful.
#23
This could get you started: Australian Hardwood Network Unfortunately, I don't find the pictures to be large enough to see well. Several of the woods look the same to me.
#24
It looks like a softwood to me,like a cypress or doug fir but I would like to know if the table is heavy....Yeah, I know, how is he going to be able to tell that, well relatively heavy. That grain in the first picture looks like it could suck up a gallon of stain.
#25
I would doubt the wood is anything we use here. It is probably something native to Australia. If it isn't, it is more likely to come from Asia. There are just too many species of wood in the world to make that call if you are not familiar with the area and the woods used there.
#26
Unless it is a table imported by department stores from America. Ever think of that? It doesn't necessarily have to be native wood. I'm making frames in the shop of Brazilian walnut....definitely not local stuff.
#27
That is a possibility, but it is more likely to made with something from that part of the world. There are many exotic woods commonly used here in the US that would not be common elsewhere. Brazilian Walnut is a common exotic here.
#28
Absolutely, we all know this could be a wood we've never seen, we're making the best guesses we can based on the woods we know.
