Concrete cleaning mix ?
fatdaddy's Avatar
WV
03-12-17, 01:09 PM   #1 (permalink)
I was told once to use 3to1 3 water 1 gallon of bleach.
How about putting Sodium Hydrocloric in there??
Put that on let set 15min and then Pressure wash it??
Marq1's Avatar
MI
03-12-17, 02:19 PM   #2 (permalink)
Save the chemicals and just pressure wash!
NJ
03-12-17, 02:32 PM   #3 (permalink)
Are you trying to remove something from the concrete other than dirt ?
~ Pete ~
fatdaddy's Avatar
WV
03-12-17, 07:13 PM   #4 (permalink)
I did pressure wash it but looked at it a month later and I see a black line from where my 25" surface cleaner went back and forth. it was driving into the drive way and you see it. I don't like it and will now go sideways but will put down some water/bleach as well.. it was my last job went looked at other jobs did not notice it as bad. I will also clean out my tips..
NJ
03-12-17, 08:44 PM   #5 (permalink)
Does that surface cleaner use spinning 0 nozzles ?
The overlap point can sometimes be seen depending on the hardness of the concrete.
I use a handheld wand with the spinning nozzle to remove visible lines like that.
Name:  pw nozzle.jpg
~ Pete ~
marksr's Avatar
TN
03-13-17, 03:39 AM   #6 (permalink)
What chemicals to use depends mostly on what needs to be cleaned off. Bleach is good for mold/mildew, detergents like TSP are good for other types of grime. Sometimes scrubbing it in with an old broom is beneficial.
In your case it really sounds like an uneven cleaning job.
retired painter/contractor avid DIYer
