The door has some dry wall?
surfbugbob's Avatar
CAL
12-26-16, 02:11 PM   #1 (permalink)
The worker fixed the dry wall on the bed wall but He made a mistakes and put the dry wall on the bed door. How do I remove the dry wall?
marksr's Avatar
TN
12-26-16, 02:15 PM   #2 (permalink)
If it's regular pre mixed joint compound it will be water soluble. If it was a setting compound you'd likely have to chip and sand it off
Any chance of getting him back to clean up his mess?
retired painter/contractor avid DIYer
surfbugbob's Avatar
CAL
12-26-16, 03:03 PM   #3 (permalink)
Can I use goof off heavy duty remover spray or goo gone to try to remove to the dry wall?
joecaption's Avatar
VA
12-26-16, 03:14 PM   #4 (permalink)
That's drywall compound, not drywall, huge difference.
Wet it down and wipe it off.
OK what's a "bed wall"?
Gunguy45's Avatar
Super Moderator
AZ
12-26-16, 05:14 PM   #5 (permalink)
Bob...why do you ask questions, then refuse to listen to the answers? If it's regular pre-mix compound, a wet rag (no soap, no goof-off, just warm/hot water) and some rubbing should take it off. If it doesn't it's a setting compound that will need to be chipped/sanded off.
If that doesn't work, you'll have to evacuate the house and burn the place down. I'M KIDDING!
And it's not dry wall, it's joint compound!
Vic
"I sometimes wonder how some people ever made it to adulthood..."
surfbugbob's Avatar
CAL
12-27-16, 08:31 AM   #6 (permalink)
Thanks. Happy Holiday!
