splitting DSL Ethernet cable...
Wouldn't this work.....
DSL Router-->RJ45 splitter(w/male cable adapter, which is plugged into router)-->two short ethernet cables connected to another RJ45 splitter(w/all female connections)-->single ethernet cable connected to another RJ45 splitter(w/all female connections)-->run one cable to DVD, run other cable to Modem.
Welcome to the forums.
You cannot "split" ethernet cables.
DSL Modem > router > one cable from router to each device.
As PJmax said, you'll either need to run dedicated cables to the router (one for each device) or your other option is to add an ethernet switch to your network, which will allow you to share your connection at an alternate location (i.e. away from your modem) amongst other devices. Unfortunately not as simple as splitting a telephone line.
Thanks.
Thanks for the reply's. I was contemplating changing my bluray from wireless to wired (to get better netflix streaming) but I still wanted to be able to browse the net on my macbook.
It sounds more complicated and expensive then I'm ready for. My DSL router only has one Ethernet output, which goes to my apple air express router.
Thanks for the info.
Amazon.com : Linksys SE1500 5-Port Fast Ethernet Switch : Network Switches : Electronics
Actually you can split an ethernet cable. You would still need 2 ports on your router though, one for each device. Then you use a pair of these:
RJ45 T Mod Splitter Computer Adaptor 10 to 100 Base Cat5e 1 Male to 2 Female | eBay
We used to do this years ago when hardware was pricey. Nowadays, buy yourself a small switch.
Switch
my air express is the a few years old.. it was the one that only came with one port and one USB (which my printer is plugged into).
So, this looks like it might do the job... It looks, more or less, like a wireless ethernet router. I wonder if its compatible with my air express.
Not really. This is the switch I have connecting my internet connection to my Wii and smart Blu Ray. Only $25.
Read more: http://www.doityourself.com/forum/co...#ixzz2udD4rvPU
It does not specifically say, but it looks like it will pick up my router with wireless. I especially think this because there is no place for an input.
Or, am I misreading this and I actually do plug my DSL modem into the switch and then also plug my router into the switch???
