Transom window repair question
Hi folks,
The glass in our over front door transom window had an accident. It's double paned, and the inner pane is shattered. I can't tell whether this is a factory assembled unit, or two panes custom installed with spacers.
I can see about 1/4 in metal spacers between the panes, which are pretty thin. Removed the wood trim at one end, and there isn't a visible frame, glass looks attached to the spacers.
I can't seem to upload/attach images - just says "upload failed" all the time...
Thanks.
Thanks.
Likely a single unit installed from the outside.
It will have to be custom made, any real glass company can do this whole job for you for you or at least have a replacement made for you.
