Windows help?
Windows help?
The entire front part of my house is made of 3 massive, single pane, non-energy-efficient windows, and I want to rip them out and re-do them.
I understand this will mean I have to add in studs and siding and insulation everywhere that I am removing windows.
We can't afford a contractor, and we do have someone who can help and follow instructions when the time comes for us to do the project, but until then, we're looking for advice and knowledge.
I have some pictures of the exterior, and can definitely get better ones, as well as getting some pictures of the inside.
What we want are 2 or 3 windows that can open, and be energy efficient.
We're also toying with the idea of a bay window/reading nook, but we're unsure of the labor involved in building one.
Welcome to the forums! Removing and replacing non energy efficient windows is common and a great boost to your bottom line of heating and cooling. It is definitely DIY (with our help, of course )
Pictures will definitely help as well as the dimensions of the existing windows and the ones you plan on installing. You may want to consider casement windows for a good flow of air on nice days. Bay or bow windows require extra framing and support, and present the most problems with add on windows.
http://www.doityourself.com/forum/el...your-post.html
Since you are new to the forums, post two now and two later on. The forum doesn't like new members posting a bunch of pictures at once.
