Dryer Vent Hookup??
Dryer Vent Hookup??
I have a new home and I have been having a problem identifying the part or who makes such a part. I have what seems like a slim dryer vent hookup.
My dryer has the standard 4" hookup and the slim inlet in the wall is a ~6" oblong (sorta rectangular in shape, but rounded off corners). I currently have a "rigged" setup, but I am worried that I am causing some mild to severs back pressure for my dryer. Does anyone have an idea where to get this part or how to identify it???
TIA's
John
Received 1 Upvote
1 Post
Have you checked at home depot and lowes they have the small flat like duct for the drier. add on to it and go into the side of the pipe.Id ask the builder who put it in and see them about getting it hooked up
ED
ED
The pipe in the wall is 6"? Not sure what you can do there.. I'd ask the builder or HVAC dealer who ran the duct.
If it's a 4" pipe that has been "squshed" to an oval. then use the foil pipe.
They did that to my parents house, there is no fitting to fit that.. What I end up doing is taking a foil dryer pipe, and that will wrap around it.. Then seal it off with foil tape.
RE: Dryer Vent Hookup??
Yeah the Dryer is a Gas dryer...
Also like I had said earlier the lenght of the inlet in the wall is an slim design.
It is ~6" in width and ~2" depth and is retangluar with rounded off corners.
I will check to see about the B hookup...
Thanks,
John
Thanks,
John
Received 1 Upvote
1 Post
Its a gas dryer he said and that has to be a gas B vent pipe it gets hot. You use this oval B pipe for inside a wall like for a gas wall heater will fit in a 2X4 wall.
ED
ED
Never heard of that.
I sell appliances, and done apppliance repairs in the past and all dryer gas or electric are vented in a regular 4" pipe. Never heard of B-vent used for gas clothes dryer. The exhaust from the clothes dryer is no hotter than the electric ones.
Unless that's code in FL to use the B-Vent.?
Same Vent Design
My new house is under construction and has the same type of dryer vent receptacle that the originator describes. There is a recessed square metal box about a foot wide and 2 feet tall that is attached to the studs. Inside, at the top of this box is a pipe that is about 6 inches wide, 2 inches deep, and has rounded corners. This connector transitions to standard 4 inch round metal dryer vent duct once it exits the box. The duct runs up tinside the wall to the attic and then runs to the outside of the house. It is for an electric dryer. I've seen them all over the neighborhood. Looks like I'm going to to need a hose for this weird thing as well!
Received 41 Upvotes
Jay
I know alot of areas requres the metal pipes vs the foil stuff.. The plastic slinky is no longer made.. At least I don't see them around here in stores.
LIke I said before, I just can't see the B-vent used for dryer venting.. The exhaust is no hotter than an electric dryer. How would a builder know if the home owner is going to use a gas or electric dryer?
Dryer Box
I think what you may have is a dryer box (www.dryerbox.com) or something similar. A rectangle with round corners is called an oval which is what is required to get a 4" pipe in a 3 ½" wall. Simply attach a flexible aluminum duct to it and tape with aluminum tape as another poster has suggested. Dryer vents are usually always single wall pipe as apposed to class "B" chimney which is double wall pipe.
