Dead Keurig brewers
Dead Keurig brewers
Two of our Kuerig brewers have now pretty much died. Well, one's definitely dead and the backup we hauled out is definitely not healthy.
Let's start with the dead one, if only because I already tore into it to see what I might be able to do.
Patient
Keurig B-70 5-speed Platinum
Presenting symptoms
No sense of power.
Procedures to date
Removed bottom plate and verified 120V into the pair of splices where the power cord ends. Noted that the spliced leads go up tpward the display and controls. Took the cupholder apart/off and started to open the top of the machine.
Prognosis
May be terminal. Not possible to determine without accessing upper portion of tower. Unsure of correct procedure.
Patient
Presenting symptoms
No sense of power.
Procedures to date
Prognosis
Has the patient lived a long and fruitful life? Is it time to "pull the plug" and let it go? Have you found any internal fuses/stints that may have failed?
Only got about 2 years on ours, no power and no lights. Other people I know have had the same. I just looked at the made in China and put it in the garage. Went back to a drip coffee maker.
From several scources including relatives and small businesses, it seems that after two years they are running on borrowed time.
Total price per cup is too much for me and my coffe habit. I'll stick with Mr. C
Well, Dr. Chandler, I would say the patient has lived a fruitful life, but it has not been very long. In fact, the patient has only been toddling for a relatively short time. While this means that a no-cost replacement is not available, we have been offered a replacement at a very attractive price. We'll probably take that offer, but I want to continue pursuing the surgery for bit longer, for several reasons:
Even with a discount, money is still money!
This exact model, the 5-speed, is no longer available, and
If, in fact, it's the logic board that has failed, I think I know where I can pick up a new one very inexpensively.
No, no internal fuses nor stints have been found during the exploratory procedures thus far made.
- Even with a discount, money is still money!
- This exact model, the 5-speed, is no longer available, and
- If, in fact, it's the logic board that has failed, I think I know where I can pick up a new one very inexpensively.
Woody and Michael, got any tips on the best way to disassemble, troubleshoot and repair my Keurig brewer? It's one of three in the house. The third-stringer is doing yeoman duty right now, but it's really a road warrior and we'd prefer to get the seasoned veteran back on the field.
Yes, the coffee is expensive if you only use ready-made K-cups. But the coffee brewed in a Keurig is the same price, if it came in a can from the grocery store, as that coffee is when it's brewed in any other machine.
We looked at a Mr. Coffee single-cup machine recently, and considered upgrading to it to replace the dead one. We decided not to. It's the same technology, a bit pricey by comparison, also made in China, and we didn't like the reason for the recent recall:
Source: Mr. Coffee
More than 600,000 coffeemakers, Chinese-made Mr. Coffee Single Cup Brewing System models, are being voluntarily recalled in the United States and Canada. A brewing malfunction can release steaming water and grounds. More than 61 injuries, including facial and hand burns, have been reported.
All kinds of used Keurig parts on Ebay .......
What's everyone doing......bustin' these things up for parts.
Looks like basic stuff to check....14.5 v power transformer, basic power supply board, brewing element, air pump motor, solenoid valve.
The basic question here is "How do I get the top off the tower off to continue checking and/or repairing?"
I was going to suggest contacting Keurig. My wife had one in her office that gave it up after a couple of years of much use and abuse. The company sent her a new one gratis.
We've had one for a couple of years and I like it. I also have the "My K Cup" filter and I usually grind my own but I really like the convenience of dropping in one of the single cup types. I pay around 50 cents a cup for a 12 pack. I don't know what the cost was with the Cuisinart we had before. With the Keuring I get no waste and I'm not buying filters.
It's also great for tea and hot chocolate and my wife can have her decaf.
We have a "My K Cup" holder with three filters plus an Ekobrew filter. Unfortunately, the "My K Cup" holder won't fit in our road warrior, so we're down to the one Ekobrew until I repair or we replace one of the programmable machines.
We both love many of the flavors that are available in the K-cups, plus the convenience and the variety. That said, I'm partial to Luzianne. I brew one of those every morning plus some flavor or other. (My coffee mug holds 24 oz.) Saves money and gives me the taste I want.
Anybody know how to get the top off of one of these in a way that will allow it to be put back on later?
I did find this. Probably not the same model but should give you some clues.
Repair Keurig Brewer - YouTube
Thanks. Different model and different problem, of course, but still some similarities. I bookmarked it.
I'm at the point of needing to get the top cover off - about 2:54 into the video - and that's what I can't figure out how to do without damaging it.
By looking at that video it looks like there are molded clips that hold the top on. This is the same principle that TV remote controls use. If you know where the clips are.....it's easy to release them.
I use a very thin screwdriver that will go between the cases and pop the clips. Sounds easy but it's not.
You have two dead soldiers there......one may have to become the guinea pig.
May have to give that up.
Ummmmmm........NOT !
Don't make me come down there and bust that bad boy open
Hmmmm... maybe I could buy a new top on eBay too...
