wiring a Bodine electric motor
I have a 2 Bodine Electric gear motors. Motor has 3 wires:1 black, 1 white, & 1 green-yellow. The grounded plug wire I am trying to use has 3: black, white, & green. If I connect the normal way(B-B, W-W, G-G&Y) the motor shutters but doesn't turn. The reason I have 2 is, the 1st motor was doing this so I thought I got a bad motor so I ordered a new 1 same as the 1st and they both are doing the same. There is no wiring diagram on motor.
Bodine gear motor
type: 42A4BEPM-5L
volts:130
Hz: DC FF 1.0
A 1.3
HP 1/6
time CONT
ratio 20;1 RPM 100
torq 63 lb-in
Bodine gear motor
type: 42A4BEPM-5L
volts:130
Hz: DC FF 1.0
A 1.3
HP 1/6
time CONT
ratio 20;1 RPM 100
torq 63 lb-in
This is a DC gearmotor. Do you have a DC power supply? If so what is the voltage?
http://www.mro-supply.net/servlet/th...ARMOTOR/Detail
BODINE ELECTRIC 42A4BEPM-5L GEARMOTOR 130V 1/6HP.
Some of electrical supply may have a small DC motor contoller for that size or Motor repair shop may have something on hand.
Merci,Marc
Merci,Marc
If you're not in a big hurry, you can just get one online. Just do a search for DC drives. Grainger has them for about $75 for that size motor. Just keep in mind, most come with 90/180 volt output so you'll need to adjust the max speed pot so it won't exceed the rating on your motor at full speed (if you wire it for 180 volts.)
Also, if possible, can you take these back and get AC gearmotors?
Looks like you have a permanent magnet DC (PMDC) right-angle gearmotor. Bodine stock model 4117 (you can tell be the serial number from the motor nameplate). If so, this is a gearmotor rated for 130VDC. At rated voltage, i.e., 130VDC, this gearmotor's armature will run at 2000 rpm, resulting in the gearmotor's rated output speed, with the 20:1 gear reduction, at 100 rpm (at 130VDC). To get the full 130VDC (out) from a 115VAC (in) speed control, you need to use a filtered control, with a form factor of 1.0 (i.e. almost "pure" DC). The Grainger control is no problem here, but it is a low-cost, unfiltered control, and it can only produce a max of 90VDC output from a 115VAC line. In a DC motor or gearmotor, output speed is proportional to input (DC) voltage. You can do the math: at 90VDC the motor will not run at 100 RPM max (out), but at a slower speed, proportional to the reduction from 130VDC to 90VDC. In this example, your max output speed will drop from the rated 100 RPM to approx. 69-70 rpm (max). Similarly with the max torque rating, you have to consider a derating by almost half. With the unfiltered control, this 130VDC gearmotor might be only run at approx. 1/12HP, and not the nameplated 1/6 HP. If you overload the gearmotor, i.e., run it at a full load of 63 lb-in, continuously, you will likely fry the armature winding, and/or the carbon brushes will wear prematurely. Your options: (1) accept that an unfiltered DC speed control won't allow you to run this motor as fast, and as hard, or (2) purchase a filtered DC control. Why are there filtered and unfiltered DC motor speed controls? Like with most things in life, there are trade-offs. Filtered DC speed controls require additional filter capacitors and circuitry on the board, so they cost more, but the filtered DC motor/control system is more efficient, performs better, and runs quieter (less audible noise). The key benefit of unfiltered controls is that they are cheaper. Hope this helps. Yes, Bodine sells filtered and unfiltered DC controls. If you go to our web site, you can get more info on the motor (including wiring instructions), and review some of our filtered control options. Good luck. ED hxxp://www.bodine-electric.com/Controls/
