GFI Hard wire 220 volt wall heater
Help please!!! New construction. Do I need to GFI a hard wired 220/ 20 amp wall heater in a bathroom? This is controled by a timer switch on the wall. I am having issues with inspection. Need to know what is the code and section if there is one pertaining to this issue. The cost of the breaker is well over $150.00. I am hoping someone can clarify the need for GFI is it is hard wire in the wall. Thanks for all help! Thw construction in southern Michigan.
What kind of heater is it (radiant panel, baseboard, heat lamp, embedded heat cable, etc) and where is it in location to the bathroom fixtures (tub, shower, lavatory)?
Does the manufacturer's instructions have any special notes regarding installation in a bathroom? Is it intended for use in the bathroom?
Usually GFCI protection is not required on built-in heaters, but the exact circumstances could change that.
Some of the bathroom heaters do require the GFCI I know enbedded infloor grid heater useally do require the GFCI however for other types most case useally not unless other situation arise or the manufacter instruction call for it.
You will have to tell us the type of heater itself and how far it away from bathtub that can be a main factor it may call for useing the GFCI.
Merci,Marc
Merci,Marc
I asked same question recently-see post at link:
http://forum.doityourself.com/electr...rotection.html
So looks like don't need GFCI, but may need a disconnect? Noone ever got back regarding my post asking if the heater mounted in wall counted as permanently mounted appliance and therefore doesn't need disconnect?
Received 38 Upvotes
If it is not cord-and-plug connected and/or is securely fastened to the wall I don't think it would be considered as anything but permanently mounted.
As for the necessity of a local disconnect...I'm too lazy today to look up all the requirements but off the top of my head I would say by a VERY strict interpretation of the NEC one might deduce that it would require a local disconnect but as a matter of real-world fact I have never seen any such disconnect in a residential setting.
thanks furd. thats what I was saying that I have never seen a local disconnect, but from the answers I was getting, I was feeling that it was required. I don't think I will put one in and if the inspector has a problem then I will put one in.
nutone 9815. the thermostat is part of the unit itself. I do not know if double pole. It is rotary-full counterclockwise is off- but it is not labeled "off". the spec sheet says" switch---on/off switch included as part of thermostat" and installation manual is here
http://www.nutone.com/PDF/InstallGui...5ins_44960.pdf
just says need to follow code. no GFCI mentioned and no disconnect. so you think inspector will want one?
