Replace switch inside metal box with ground attached to box
Hi.
If I'm replacing a switch and the original switch doesn't have ground attached to it, but instead the ground coming from the cable is screwed to the metal box, do I have to attach a pigtail from the new switch to the ground or box?
I read that the switch will be in contact with the box when it's screwed in and won't need to be attached to the ground wire via the ground screw.
