ceiling fan does not spin counterclockwise
My ceiling fan has a reverse blade button that you could use to change the rotation path of the blades; it would spin clockwise and counter-clockwise. Now, it will only turn clockwise; the reverse button does not work. Can I repair this or is it a lost cause? I have two fans like this. The fans came with the house so I do not have access to a manual.
That's a pretty easy fix as I recall. Couple of screws and two or three wires. Turn off power and remove the light fixture or cover that will access the switch and have a look. May only be a case of wire-nutting in a new switch.
Sure.
Step #1, make sure the POWER IS OFF.
Step #2, gain access to where the switch is mounted. This will involve either removing the small round cover plate on the bottom or the light fixture if so equipped. If it has a light fixture you will need to be careful that you don't pull any wires loose. Do not allow light fixture to hang by the wires. Under the cover/fixture you will find a collection of wires. The various connections will likely be made using wirenuts which are small plastic cone shaped wire connectors. To remove a wire nut, hold the wires and turn the wirenut counterclockwise, just like removing a nut. With the wirenut off, you will see the wires twisted together and be able to see how the wirenut works. Locate the switch in question. It should be held into the housing using a couple of screws. Remove screws. Locate the wires coming from switch and draw yourself a diagram of what wires go where for future reference.
Best way to proceed will be to have the new switch in hand before removing old switch, but you may need to take the switch along for comparison. If your local home center doesn't have a replacement switch, try Radio Shack.
You might want to do a reconnaisance on the wiring and post back here before you actually start any repairs.
Most important thing to remember: ENSURE POWER IS OFF.
ceiling fan
dear Tow guy,
I opened the switch area and there are alot of wires; the switch mechanism has white, purple, and brown wires attached to it;
how do you disconnect the wires from the switch mechanism to replace it? I wanted to check to see if there is continuity in the switch mechanism, but I cannot disconnect the wires to test it;
please help!
sincerely,
arika
please help!
sincerely,
arika
Arika, Sure you can test it. Just cut the wires and check the switch. You can aways wire nut them back if the switch is ok. Some times the wires are connected together with a crimp type wire nut. you just have to cut them off also and use standard twist type wire nuts to reconnect them. OK? Jay
ceiling fan
dear tow guy...............
thank you for all your help.............. it works! I did not have to go out and buy a new fan.................. thanks alot......
it was a cinch except, how do you attach the wired to the small terminals? I just squished them together and hope that they do not come loose! (yikers); furthermore, how do you test for continuity with the old slide switch? there are six terminals.
thanks for your help!
arika
arika
