List of available sensor names for Simon XT
I have a Simon XT revision 1.4. When I program names for the sensors, I have noticed that if I choose [space] for the first position, then a whole new set of names becomes available. If I chose [space] again, then a third set of choices becomes available.
Cycling through all the names one by one is tedious. Plus there are so many choices, it is hard to keep track of what names are available.
Is there a published list that would show me all the available names? My manual does have a table called "Sensor names". However, it is not complete.
The list in the back of the manual beginning on page 67 is the available list: http://download.homesecuritystore.co...TI_Install.pdf
The trick of this is that the names are segments that you can put together to make combinations, or you can spell stuff out, letter by letter, (only the defined segments get verbally announced)
Thanks. This is just what I needed. For some reason the manual that I have only lists sensor names 1 through 128. The manual you referenced has all the sensor names. That's great!
