DSC pc1555 installer code
I am hoping there might be something new on determining the installer code. My system is not being monitored and I keep getting the beeping because it can't communicate. I understand that this can't be done with the master code. We recently had a power outage and just about every light was lit on the panel. I found the circuit breaker and turned that off and on again luckily that cleared out all the trouble issues and I reset the time and date but the beeping issue is not solved. Any help would be appreciated.
I have same problem as you.
I didn't care about the beeping and after about 1 month or maybe more it stopped beeping and I can't arm it anymore. Ready is not on.
BTW , how long was your power outage?
If you do *2 you only get error #4 ?
