DSC PC5010 still showing error code 7 (sensor low bat)
gogogranny's Avatar
CAL
09-11-17, 07:45 PM   #1 (permalink)
Manual says if you hit 7 again up to 4 times it will show affected sensor (in groups of 8).
Since I was unable to get it to do this, I went around and tested batteries in every wireless PIR.
Sure enough one was low. So I replace the low bat w/ a tested good one but I still cannot arm due to same (7) error.
What might I be missing?
Thanks in advance for any assistance.
JG
MrRonFL's Avatar
FL
09-12-17, 06:19 AM   #2 (permalink)
Is the device remounted? How many wireless devices do you have? What keypad model do you have?
"Ask the Right Question..."
- from _The Snow Queen_ by Joan D. Vinge-
gogogranny's Avatar
CAL
09-12-17, 07:00 PM   #3 (permalink)
Hi,
I have 5 wireless sensors and two LED5508s KPs (in addition to various wired components).
It does not provide feedback thru the KP as to which channel.
Thank you.
ThisOldMan's Avatar
TN
09-14-17, 02:25 PM   #4 (permalink)
This is "old school" but,
  1. remove the battery,
  2. short the battery contacts on the device (NOT the battery) for a few seconds,
  3. reinstall the battery and the device.
You can use anything conductive to short the contacts.
MrRonFL's Avatar
FL
09-14-17, 02:46 PM   #5 (permalink)
Actually, the repeated pressing of [7] shows the first 8 zones, then the wireless keypads, then the wireless keyfobs. Sadly the LED keypad model only displays the first 8 zones. Some of the older DSC wireless are _very_ fussy about batteries, and batteries that are "new" but a little too long in shelf life might not work. You may simply have to methodically replace _all_ of the batteries, methodically.
