Adding Multipul Fireplace Doors
02-25-00, 01:29 PM #1Visiting Guest
I recently purchased a home w/ a fireplace in the basement. Unfortunatly, it is positioned in such a way that you can't really enjoy it while making the most of the surrounding space. I was wondering if it is possible to make it so that the opening to the fireplace was visual from 2-3 sides rather than the traditional 1 side only. If anyone has any suggestions on how to do this I would greatly appreciate it.
02-25-00, 06:35 PM #2Visiting Guest
If your fp dosn't have a good "view", you can try to mirror it by installing mirrored squares on the wall closest to it.
02-25-00, 08:38 PM #3Visiting Guest
Hi:Ingrid
Best solution I can muster up is contact a fireplace brick mason or contractor.
Check the yellow pages. Call some fireplace shops and ask several general contractors for estimates or referrals.
Anything like this is possible if money isn't an object.
Good Luck,
TomBartco
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
