Counter Sink Drill Bits
GregInGA's Avatar
GA
07-18-17, 12:37 PM   #1 (permalink)
Don't counter sink drill bits create a cone shaped hole? I have to counter sink a thru bolt with a hex head in a wooden work bench surface so that the top of the bolt is flush with the wooden surface I am dropping it into. Will a counter sink bit that creates a cone shaped hole be OK for this or is there another kind of counter sink bit that should be used for hex head bolts
NJ
07-18-17, 12:50 PM   #2 (permalink)
When you need to countersink hex head bolts..... use a spade bit first to drill the depth of the head. Then drill the hole for the bolt itself.
Keep the spade bit slightly on the smaller size as you'll need to tap the hex head into the wood to keep it from spinning when tightening.
Carriage bolts also make a good fastener for table tops and workbenches.
No countersinking required.
~ Pete ~
XSleeper's Avatar
NE
07-18-17, 01:36 PM   #3 (permalink)
Just to add to what Pete said, you might also want to use a washer with your hex bolts. (Don't need them with carriage bolts.) And drill slowly... those spade bits will drill pretty fast and you don't want your countersunk hole to be too deep, so go slow.
Norm201's Avatar
NY
07-18-17, 02:00 PM   #4 (permalink)
What you want is a counter bore, not counter sink. The spade drills mentioned by PJ along with the washers Xsleep mentions are the way to go. They do make counter bore bits if you want accuracy.
Norm201's Avatar
NY
07-18-17, 05:45 PM   #5 (permalink)
difference between counter sink and counter bore
Tolyn Ironhand's Avatar
MN
07-18-17, 05:56 PM   #6 (permalink)
Forstner bits make great flat bottom holes. Drill the counter bore first and the follow up with the regular drill bit.
Electrical AC/DC and lighting Moderator
Professional Electrician, Handyman, all around swell guy!
40,000 people die in auto accidents per year in the US. We should ban cars.
Marq1's Avatar
MI
07-19-17, 02:27 AM   #7 (permalink)
Spade bits are somewhat crude, work OK for decks and pick nick tables, but forstner bits are much more precise for furniture and trim.
Just another right tool for the right application.
GregInGA's Avatar
GA
07-19-17, 05:32 AM   #8 (permalink)
Yes, from the pictures, that looks correct, counterbore. The spade bit should work, no need for the accuracy of a forstner. I assume it's OK for the outer hole created by the spade bit to be a little larger than the head of the thru bolt?
Norm201's Avatar
NY
07-19-17, 05:38 AM   #9 (permalink)
If you need to buy the bits, go for the forstner, it will be useful for later projects. But if you already have the spade drill bits then just use them.
XSleeper's Avatar
NE
07-19-17, 05:41 AM   #10 (permalink)
Use the bit that is the same size as your washer. 5/16 = 5/8 and 3/8 = 3/4 if memory serves. (Bolt / spade)
GregInGA's Avatar
GA
07-19-17, 05:51 AM   #11 (permalink)
I noticed the spade bits pictured by PJMaxhave a sharp pointed tip, as do they ones I own:
. The Dewalt ones I saw yesterday in the store have a threaded end with a sharp tip:
. What's the difference, does it matter?
Norm201's Avatar
NY
07-19-17, 05:59 AM   #12 (permalink)
Not really!_______________________________________
marksr's Avatar
TN
07-19-17, 06:02 AM   #13 (permalink)
I have both, the ones pictured at the top are easier to sharpen but the bottom pic [imo] does a better/quicker job.
retired painter/contractor avid DIYer
XSleeper's Avatar
NE
07-19-17, 06:37 AM   #14 (permalink)
The threaded tip helps pull the bit forward for faster drilling... not what you want if you only want a shallow hole. But thats why it says 10x faster.
GregInGA's Avatar
GA
07-19-17, 06:47 AM   #15 (permalink)
I assume that it would be OK to make the outer hole a little larger than the distance across the hex head of the bolt, e.g. the hex head of the thru bolt is 1/2" across, so I am guessing a 5/8" or 3/4" spade/forstner bit would be best. I'd hate to but a 1/2" bit and then find out the hex head is really 17/32" not 1/2"
marksr's Avatar
TN
07-19-17, 06:57 AM   #16 (permalink)
Don't forget the size of the washer, that helps prevent the bolt head from digging into the wood.
GregInGA's Avatar
GA
07-19-17, 07:02 AM   #17 (permalink)
Ahhh, good thought, I definitely will do that
