Tree Trimming - maple lower branches
stanj's Avatar
MD
08-05-17, 02:41 PM   #1 (permalink)
I have some maple trees that have lower branches about 6 feet up on the trunk that are 5-6 ft long. They were bending over and was making it difficult to mow around the trees on a riding mower as I had to use my hand to move some away as a i passed.
Some would almost touch the ground when it rains.
I started to cut some of them back.
Attached is a photo of a lower branch / branches I cut.
Question is
Should i cut the branches all the way back to the trunk?
thanksName:  maple.jpg
Gunguy45's Avatar
Super Moderator
AZ
08-05-17, 02:51 PM   #2 (permalink)
Just do a quick search for pruning low hanging branches. Yes they can and should be trimmed, but there is a right way and a wrong way. Will take 3 cuts.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
Marq1's Avatar
MI
08-06-17, 04:53 AM   #3 (permalink)
If all you did was trim some small branches off a larger branch but there are still other smaller branches, with leaves, coming off that larger branch then you are fine.
XSleeper's Avatar
NE
08-06-17, 05:35 AM   #4 (permalink)
Yes, soft maples need to be trimmed frequently. And not just the branches that are in your way. They are usually the trees most susceptible to storm damage. So looking for branches that need trimmed is a wise precaution. Dont cut too close to the trunk however. There is usually a wrinkle in the bark below the branch that you want to just barely leave.
stanj's Avatar
MD
08-08-17, 06:02 PM   #5 (permalink)
Thanks
A few more pics
Should I take the limbs marked with arrows back to single limb?
XSleeper's Avatar
NE
08-08-17, 06:45 PM   #6 (permalink)
I would follow that branch down to the trunk and cut it off at the trunk. It and the one next to it at the trunk. And maybe even the lowest one on the left side. And the middle of the tree looks very congested. You could trim a lot out of the middle and eliminate a lot of those places where 3 or 4 branches all stem from the same spot.
stanj's Avatar
MD
08-10-17, 05:25 PM   #7 (permalink)
Thanks..
I started to cut them back to trunk. I have 4 maples to work on and already accumulated a load of branches.
I also have to work on two birch trees.
XSleeper's Avatar
NE
08-10-17, 05:39 PM   #8 (permalink)
Hope your burn pile is nearby!
stanj's Avatar
MD
08-17-17, 05:52 PM   #9 (permalink)
The burn pile will be in my garden once fall arrives. Will make a nice bon fire
I have another trimming question. I have moved from trimming the maples to trimming a tree near our garage. A landscaper planted it there and I have no idea what it is. It has been dropping little white flowers all over the side walk and driveway. This gets tracked into the house and garage. In the fall, black seeds drop all over the drive and also was clogging up the gutter over the garage.
When the tree was small, it was not an issue. But the branches were hanging over the sidewalk, garage roof, and driveway. It was hard to just cut the ends with the flower clusters because they are so thin and the branches are long as seen in the photos, so I took a lot off.
Question is, in the attached, should I take the branches back to the trunk?
Should I remove the tops by cutting the branches ?
These don't bother me too much because they are not overhanging the steps or sidewalk.
XSleeper's Avatar
NE
08-17-17, 07:21 PM   #10 (permalink)
I'm not familiar with that tree, I would hesitate to give advice on pruning it. My first impression is that it may have outgrown it's attractive size. If it was my tree, I think that late this fall I would try topping off the entire tree, in a fan shape, and lose the top 1/3 of the tree... roughly from the bottom of the upstairs windows crowned to midway up those windows... just above that sporadic growth. Then see how it reacts to the pruning next year.
Ornamental trees simply need to be replaced from time to time when they outgrow their attractiveness.
guyold's Avatar
CT
08-17-17, 07:25 PM   #11 (permalink)
Might be a Natchez Crape Myrtle Tree. Had to look it up once I saw the bark.
XSleeper's Avatar
NE
08-17-17, 07:42 PM   #12 (permalink)
Good call, guyold. We don't have many of those around here.
Here is a video that describes exactly what I was suggesting. Notice at the end of his video how he leaves the forks of the branches... the size of branch, and how it eliminates crossover and opens the interior of the tree. I mentioned late fall, he is pruning at the start of winter... main thing is the leaves have all gone.
Also, you aren't cutting it in a "perfect" fan shape as if you were trmiming a hedge... but alternating some high and low cuts... picking your spots based on the optimum location to prune, while you attempt to create an "average" fan shape.
You might also watch some crepe "murder" videos for what not to do.
Gunguy45's Avatar
Super Moderator
AZ
08-17-17, 10:37 PM   #13 (permalink)
Crepe Myrtles back in VA were trimmed back each year to a bulge in the main branch, then it would grow new from the cut line. I've seen them cut from about 8 ft down to about three and thinned drastically and they came back health as can be. Kind of like roses.
Larry said in his area, they trimmed Crepe Myrtles with a backhoe.
Get some local advice on how much you can prune, but you should be able to make it into a nice thick lower growing shrub. Ideal would probably be somewhere around that little cluster of green at the level of the 2nd story windowsill in pic 4.
Vic
stanj's Avatar
MD
Yesterday, 09:25 AM   #14 (permalink)
Excellent,,guygold ..xsleeper
Great call...I dug out some folders I keep all of the landscaping info in and verified that, indeed, it is a Natchez Crape Myrtle planted in 2004.
The video is spot on what I was / am trying. Using a small hand saw and tree trimmer, removing a lot of the lower big branches.
In the new attached, you can see an old pic of when it was planted.
If you note, on the left side is a yoshino cherry, which is next on the list. I will post a pic of what it looks like today
So,in the second pic posted, if you see where I have the red line, I should start removing the area at the top?
The wife said take it down,,,but I want to keep it as it is nice, just need to maintain the growth so it does not get out of control..
Gunguy45's Avatar
Super Moderator
AZ
Yesterday, 12:47 PM   #15 (permalink)
I know it may seem excessive, but I'd take it to the height it was originally (about where I said earlier). It will grow new shoots/branches/canes/whatever they're called from where you cut.If you only go to the red line you marked, you'll be back to what you have now by the end of next year.
Vic
XSleeper's Avatar
NE
Yesterday, 01:23 PM   #16 (permalink)
I agree... way lower. In your picture i would suggest you cut across a line that is even with the bottom of your upstairs windows... as viewed in the photo. Thats probably 7' below your red line.
if you stand on an 8' stepladder and cut as high as you can reach that might be about right.
