forced air furnace
forced air furnace
furnace pilot keeps going out. replaced thermal coupler worked for awhile and started acting up again. after lighting furnace again i bumped the regulator by accident and it shut the hole furnace down. i have replaced thermal coupler twice in two years,advice on problem would be highly appreciated. THANK YOU
Received 7 Upvotes
More Information Requested
Hello Manofsteel65327. Welcome to our Heating and Cooling forum and the Do-It-Yourself Web Site.
There could be any number of possible problems causing the described problem. Far too many too explain here. We need to narrow down the list of possibilities. Potential problems could be a cracked or damaged firebox. Smothering flames is yet another.
Please provide in depth, specific & detailed information regarding the problem, helps to explain the situation your dealing with in a manner that allows myself and or several other professionals, in this forum, to offer the best possible helpful suggestions and advice.
Also provide the units brand name, year, model, serial numbers, if available, type of ignition system and the location of the heating unit. Any and all detailed information would help greatly.
Any and all additional detailed information you can provide may help to expose a clue regarding the heaters current problem and help us to determine the exact repair to the problem.
Your assistance in this matter would be beneficial.
To add more information, please use the REPLY button. By doing so, the additional information you add will remain within this posting {Thread} and allow the professionals in this forum to follow the topic and reply with helpful advice and suggestions.
Suggestions:
Read the manufacturers online web site for product information, problem solving methods, disassembly, reassembly methods, repair proceedures and instructions, pictorials and schematics, which may be available online.
Retail parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers if you stop in at the store. The info will help to determine the ignition system and possible problem causes.
Check among the RECENT postings and ARCHIVES, within this forum, for other postings on your topic, specific appliances problem or conditions and read the replies offered.
Chances are the topic, condition and or problem has already been covered in complete detail.
Regards & Good Luck, Forum Host & Moderator.
TCB4U2B2B Company Enterprises. Energy Conservation Consultants & Gas Appliance Diagnostics Technicians.
Suggestions:
