Login to DoItYourself
Forgot username or password?
Or Login with Facebook
Don't Have an account? Sign Up Today
Login
Sign Up
How-Tos
1000's of Articles & Videos
Forums
Get Expert Help
Did It Myself
Share Your Projects
search
    • New Posts
    • Today's Posts
    • FAQ
    • Calendar
    • Community
      • Member List
    • Forum Actions
      • Mark Forums Read
    • Quick Links
      • View Forum Leaders
    • Search
  • Home
  • Forum
  • Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls
  • Gas and Oil Home Heating Furnaces
replacing thermal coupler
The Facebook Platform
Login | FAQ
Results 1 to 5 of 5
  • LinkBack
    • LinkBack URL LinkBack URL
    • About LinkBacks About LinkBacks
  • Thread Tools
    • Show Printable Version
    • Email this Page…
    • Subscribe to this Thread…
  • Search Thread
    • Advanced Search
  • Display
    • Switch to Hybrid Mode
    • Switch to Threaded Mode
  1. 10-31-04, 01:10 PM #1
    bryansauer
    bryansauer is offline Member
    Join Date
    Oct 2003
    Posts
    60
    The furnace I have does not turn on, the gas is on and the guy that turned on the gas relit the pilot and said it didn't stay on, and that he thought i needed a new thermal coupler. i know nothing about furnace stuff and was wondering if this is something I can do, and how to do it. I am fairly handy around the house but haven't done any furnace work (haven't had to as of yet). The heating companies I called said it is at least 80$ just to come out.
    Thanks much.
  2. Sponsored Links
  3. 10-31-04, 01:27 PM #2
    Sharp Advice's Avatar
    Sharp Advice
    Sharp Advice is offline Admin, Forums Host & Manager
    Join Date
    Feb 1998
    State:
    CAL
    Posts
    13,005
    Hello bryansauer. Welcome to the Heating Furnaces forum topic and the Do It Yourself Web Site.
    The thermocouple is an element that is secured into the pilot assembly where the pilot flame is. The pilot flame is heating it. The other end of the thermocouple is screwed into the gas control valve.
    A thermocouple is generic except for it's length. Thermocouples are made in different lengths. Measure the removed part or take the one you remove to any hardware store and replace it with an exact duplicate in length. The parts cost is very nominal.
    New thermocouple packages will contain complete do-it-yourself installation instructions and pictures. The package also contains additional clips of various assortments. None may not even be needed.
    Not all the parts contained in the package with the thermocouple will be needed. The packages contain an assortment of holding parts and clips that are generic and designed to fit a wide variety of applications.
    Install new T-Couple into pilot assembly exactly as the existing one is installed. Element end must be placed exactly the same height as the exiting one. Reinstall pilot assembly as found.
    Gently thread nut end of T-Couple into gas control valve, starting threads by hand to insure threads will not cross thread and become damaged. Tighten nut snugly but do not overtighten. Just snugly until lightly bottoms out.
    Be sure the pilot flame is all blue and no yellow. If any yellow or doubt pilot flame is correct or maybe dusty, clean it out. Blow out pilot flame & allow assembly to cool. Use can of computer keyboard canned air cleaner to blow out the entire assembly.
    Relight pilot and note the result. Test the pilot again note any changes. Also be sure the T-Couple is correctly installed in the pilot assembly. Only the tip of T-Couple or about top 1/3 should be heated. Must be glowing a bright cherry red color.
    If you need further assistance, use the REPLY button to add any additional information or ask additional questions after attempting the correctional method or methods offered.
    Regards & Good Luck, Sharp Advice.
    Web Site Host, Forums Monitor & Multiple Topic Moderator.
    TCB4U2B2B Company Enterprises. Energy Conservation Consultant & Gas Appliance Diagnostics Technician.
    Personal Reminder:
    Buckle Up & Drive Safely.
    "The Life You Save, May Be Your Own."
  4. 11-02-04, 12:03 PM #3
    bryansauer
    Join Date
    Oct 2003
    Posts
    60
    trouble
    i am having a bit of trouble installing this thermocoupler. i have removed the old one, however i cannot get the new one in the pilot bracket. the old one only was removed because the copper wire and end near the pilot became unattached (ie. the copper wire was probably cracked and when i moved it it just split into two pieces). then i pulled the old coupler end out as if it would be going thru the pilot flame if it was lit, but my directions said i should pull it out the other way (which i couldn't do, but didn't have to because the copper wire/coupler broke). Now, the new thermal coupler cannot be inserted up thru the pilot bracket, it is too big, and i can't make it go thru the other way becasue the end of the if has the threading unti to attach to the gas valve. anythoughts? the pilot bracket seems to not be unattachable so i'm not sure.
  5. 11-02-04, 03:26 PM #4
    Ed Imeduc's Avatar
    Ed Imeduc
    Ed Imeduc is offline Member
    Join Date
    Aug 2002
    State:
    MO
    Posts
    18,457
    Wink
    See if there is a nut there on the bottom of the pilot for the T/C take it out and see if it works. On the card that the T/C was on should show you how it goes in. Most fit lots of different pilots.
    ED
  6. 11-05-04, 07:16 AM #5
    dxbeck Visiting Guest
    thermocouple replaced, furnace now working
    Dear Ed and website hosts,
    Thanks for the free info on what a thermocouple is and how to replace it. I replaced the one on my mom's Montgomery Ward wall furnace and it is now working great. It saved her a lot of money.
    Steve
+ Reply to Thread
« Previous Thread | Next Thread »
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
  • BB code is On
  • Smilies are On
  • [IMG] code is On
  • HTML code is Off
  • Trackbacks are On
  • Pingbacks are On
  • Refbacks are On
Forum Rules
  • similar threads
    • gas furnace stopped working
    • Perfection Heater
    • Suggestions for locating a thermal coupler
    • forced air furnace
    • thermal coupler
  • newsletter sign-up
    signup
  • need project help?
    help
  • Follow @DoItYourselfcom
  • related ads
DoItYourself.com®, founded in 1995, is the leading independent home improvement and repair website. We welcome your comments and suggestions. All information is provided "AS IS." Website operating problems contact Webmaster. Questions of a Do It Yourself nature should be submitted to our "DoItYourself.com Community Forums". Copyright © 1995-2011 DoItYourself.com Inc. All rights reserved. You may freely link to this site, and use it for non-commercial use subject to our terms and conditions of use. View our Privacy Policy here.
RSS feed | Advertise | Find a Contractor | Interactive How-to's | About Us | Terms | Privacy Policy | Site Map
DoItYourself.com is an INTERNET BRANDS company.
  • Contact Us
  • DoItYourself.com
  • Archive
  • Privacy Statement
  • Mobile Site
  • Top
Powered by vBulletin™ Version 4.1.11 Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Content Relevant URLs by vBSEO 3.6.0
