Login to DoItYourself
Forgot username or password?
Or Login with Facebook
Don't Have an account? Sign Up Today
Login
Sign Up
How-Tos
1000's of Articles & Videos
Forums
Get Expert Help
Did It Myself
Share Your Projects
search
    • New Posts
    • Today's Posts
    • FAQ
    • Calendar
    • Community
      • Member List
    • Forum Actions
      • Mark Forums Read
    • Quick Links
      • View Forum Leaders
    • Search
  • Home
  • Forum
  • Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls
  • Gas and Oil Home Heating Furnaces
Reznor F75 natural gas heater
The Facebook Platform
Login | FAQ
Results 1 to 9 of 9
  • LinkBack
    • LinkBack URL LinkBack URL
    • About LinkBacks About LinkBacks
  • Thread Tools
    • Show Printable Version
    • Email this Page…
    • Subscribe to this Thread…
  • Search Thread
    • Advanced Search
  • Display
    • Switch to Hybrid Mode
    • Switch to Threaded Mode
  1. 09-09-07, 05:22 AM #1
    rootercycles
    rootercycles is offline Member
    Join Date
    Sep 2007
    State:
    MN
    Posts
    11
    I have recently installed an old (1989) Reznor heater. It is natural gas and I have been able to get it up to the point of keeping the pilot light lit. It is a match light system. When I turn the selector knob to "on", nothing happens. I don't hear a change in gas velocity or anything else. The electriciy is on to the heater and the pilot stays lit. I recently had a heater guy install an in-line regulator. Before that, the gas poured out. How do I get this thing to fire? I haven't checked to see if the fan works, and the system is not hooked up to a thermostat. Those two wires are spliced together. I am trying to get this thing going before it gets really cold here in MN! I have also got more money in this thing than I originally planned, so I want to do as much as I can myself. I have looked online for a wiring diagram for the unit without success. HELP!
  2. Sponsored Links
  3. 09-09-07, 01:09 PM #2
    daddyjohn
    daddyjohn is offline Member
    Join Date
    Aug 2007
    Posts
    1,994
    Quote Originally Posted by rootercycles View Post
    There are plenty of wiring diagrams at reznor's website. Your unit should be fairly simple. The circuit should go from the the transformer [unless you unit is line voltage then there won't be a transformer] to a limit switch, then to the thermostat. then to the =ga svavlve, then back to the other side of the gas valve. So first thibng to do is check to see if you have voltage at the gas valve. If not, look for a high temperature limit switch and see if it's open.
  4. 09-09-07, 01:45 PM #3
    Ed Imeduc's Avatar
    Ed Imeduc
    Ed Imeduc is offline Member
    Join Date
    Aug 2002
    State:
    MO
    Posts
    18,457
    Wink
    Why did he do that???? didnt it have on on???? This unit wasnt on LP was it??? Did he set it and check itwith a manometer?????
  5. 09-09-07, 04:12 PM #4
    rootercycles
    Join Date
    Sep 2007
    State:
    MN
    Posts
    11
    my heater
    he put the regulator on because it didn't have one. He said that where I live the gas is under high pressure and needed to have a regulator on the unit. I don't believe he checked it with any meter. Regarding all of the information that daddyjohn submitted, I have no idea what most of that means. My electrical skills are limited when related to gas heaters. How would I decipher where the gas valve is? The unit does not appear to have a thermostat. I have bought an external one if that is what you mean. The wires that are connected to the thermocoupler are spliced together. Is that where the external thermostat goes? There are a couple of other wires (red) spliced together where it is connected to some sort of voltage regulator that then goes to the fan motor. I do hear a slight "buzzing" noise when I turn on the fuse to the system. I am a little wary testing the fan without the transformer or whatever reulator it is attached to so as not to burn it up with too much voltage.
  6. 09-09-07, 09:01 PM #5
    Ed Imeduc's Avatar
    Ed Imeduc
    Join Date
    Aug 2002
    State:
    MO
    Posts
    18,457
    Wink
    Do you have LP there or Nat gas?????? What does the unit say what kind of gas????
  7. 09-10-07, 03:52 AM #6
    rootercycles
    Join Date
    Sep 2007
    State:
    MN
    Posts
    11
    It is natural gas. I hope to have this thing runnning soon. I think it is an electrical problem.
  8. 09-11-07, 03:48 PM #7
    daddyjohn
    Join Date
    Aug 2007
    Posts
    1,994
    The gas piping going to the unit will go straight to the gas valve. On the side of the unit there should be a dataplate and also a replacement parts tag. Did you look at Reznor's website? There are installation manuals and parts manuals for your model there. The install manual has the wiring diagram you're looking for.
  9. 09-12-07, 03:46 AM #8
    rootercycles
    Join Date
    Sep 2007
    State:
    MN
    Posts
    11
    are you saying this thing doesn't need a regulator?
  10. 09-12-07, 01:53 PM #9
    daddyjohn
    Join Date
    Aug 2007
    Posts
    1,994
    sorry foir the confusion- what I mean is if you follow along the gas piping, you can trace along it to the gas valve. I think the word straight may have confused you.
+ Reply to Thread
« Previous Thread | Next Thread »
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
  • BB code is On
  • Smilies are On
  • [IMG] code is On
  • HTML code is Off
  • Trackbacks are On
  • Pingbacks are On
  • Refbacks are On
Forum Rules
  • similar threads
    • Hot Water Heater Thermocoupler - Too Long OK?
    • gas wall heater
    • heat turns pilot light off
    • pilot on gas heater
  • newsletter sign-up
    signup
  • need project help?
    help
  • Follow @DoItYourselfcom
  • related ads
DoItYourself.com®, founded in 1995, is the leading independent home improvement and repair website. We welcome your comments and suggestions. All information is provided "AS IS." Website operating problems contact Webmaster. Questions of a Do It Yourself nature should be submitted to our "DoItYourself.com Community Forums". Copyright © 1995-2011 DoItYourself.com Inc. All rights reserved. You may freely link to this site, and use it for non-commercial use subject to our terms and conditions of use. View our Privacy Policy here.
RSS feed | Advertise | Find a Contractor | Interactive How-to's | About Us | Terms | Privacy Policy | Site Map
DoItYourself.com is an INTERNET BRANDS company.
  • Contact Us
  • DoItYourself.com
  • Archive
  • Privacy Statement
  • Mobile Site
  • Top
Powered by vBulletin™ Version 4.1.11 Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Content Relevant URLs by vBSEO 3.6.0
