Where can I find the fuse in my furnace?
I have an Amana Air Command 80 Model GUI-D gas fired warm air furnace (approx 12 years old) - Model # GUI090D30A. I was replacing the Honeywell thermostat with a Hunter thermostat (heater worked but not air conditioner so I changed a couple of wires around and created an arch which I am assuming blew a fuse. I cannot locate the fuse in the furnace - any help would be greatly appreciated!
Transformer issues
If you have a fuse it will be in your control box in the bottom compartment with the blower. If there is a pc board in the control box the fuse usually plugs into the board, if not the fuse will be on one of the transformer secondary wires. If there is no fuse you may have burned up the transformer. and it will have to be replaced.
You assume that you blew a fuse because of an arc. Where was the arc. If it was at the thermostat, you may not have hurt anything. Have you tried the furnace to see if it is coming on when you set the thermostat to a higher than room temperature. Usually a brief arc on the low voltage side of a transformer will not cause it to fail.
unit mounted within the furnace on the 24V side is rare on residential furnaces.the TR itself might have a in line fuse link inside the 24V side but not replaceable.you need to change the TR out 115V/208V-24V...40 VA
Thanks all for the responses. 1. I reset all the breakers, 2. tried replacing the old unit with no success. Replacing the transformer is my next step. Connecting the wires at the thermostat will be the next big challenge if the transformer does the trick. Stay tuned
Sure enough - - it was the transformer in the furnace that needed to be replaced. All is well and we have heat (and A/C) when we need it.
Thank you for all the responses. This is a VERY helpful site!
