Furnace Efficiency
11-21-08, 10:18 AM #1
- Join Date
- Nov 2008
- Posts
- 3
Furnace Efficiency
I have recently bought a house (870 sq.ft),1985 built. It is equipped with keeprite furnace as old as house. Being a rookie from other country , where no furnace heating is required, I have no experience. All is working well, but for my own knowledge I wanted to know if this house is insulated well. I have kept the indoor temperature @ 19 degrees. The outdoor temp. now a day is -15 degrees and with the wind chill -25 degrees. The furnace once reaching to set temp., restarts after every 15 minutes, keeps running for 7-8 minutes. I dont know if this is fair enough effeciancy of the house and furnace. Thanks for your advice in advance.
11-21-08, 08:31 PM #2
Furnace efficiency
If the exhaust pipe on the furnace is white plastic the furnace is at least 90% efficient. If the exhaust pipe is metal, the furnace is only in the 80% range.
Look in the attic for insulation, measure the thickness & post the thickness & type of insulation and we should be able to give you an 'R' value. If the house is over a crawl space or unheated basement, check also the insulation under the floor.Work is for those who don't know how to fish.
Grady
11-24-08, 06:45 AM #3
- Join Date
- Nov 2008
- Posts
- 3
Thanks for responding!! The insulation in the attic is spray foam type with a thickness of +1'-0". The exhaust pipe of the furnance is metal. The basement/lower level of my bi-level house is fully furnished with flooring as slab on grade.
Hope you would be able to tell me the R value with this.
Thanks in advance
11-24-08, 08:14 AM #4
- Join Date
- May 2007
- State:
- WI
- City:
- Eau Claire
- Posts
- 8,629
Foam? Where are you located?
I am not familiar with spray foam used for attics. I know it is done for walls, but never heard of it for ceilings, perhaps due to a weight factor?
But foam will have a far higher insulated rating than fiberglass, which would be R-38, if you had a foot of that. I would not doubt you are around 50, give or take some.
11-24-08, 12:05 PM #5
- Join Date
- Nov 2008
- Posts
- 3
It is actually blown -in insulation, Sorry about my no or less knowledge.
11-24-08, 02:43 PM #6
- Join Date
- May 2007
- State:
- WI
- City:
- Eau Claire
- Posts
- 8,629
One foot of that real loose white fluffy fiberglass that does not itch, would not be as good as 1 foot of cellulose. So you really need to know what you have.
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
