Timer/relay wiring questions
Joker330's Avatar
WI
03-10-17, 05:10 AM   #1 (permalink)
First timer here!
I have a project that I am working on but am what you would call "alternating current dumb" I need to know how to hook up my components to make them work. What I have is..
1. RH2B-U-AC24V
2. finder 81.01 timer
3. A/C motor
4. A/C actuated valve
5. power cord
I need to plug in my power cord and have the motor run for 2min. then shut off and have the valve open for 3sec. Then have the motor turn on again. This cycle needs to continue continuously. I have no idea where to connect any of the wires. Thanks in advance for the help
NJ
03-10-17, 09:55 AM   #2 (permalink)
Welcome to the forums.
Is this the timer you have..... FINDER_RELAYS_S81EN.pdf
What voltage is the AC motor ?
What voltage is the AC valve ?
You may not need a relay.
~ Pete ~
