Installing Pre-Hung French Double Doors - Jamb Wider than Door
02-07-12, 04:53 AM #1
- Join Date
- Jan 2012
- State:
- PA
- Posts
- 7
So, I will preface this by saying that I have never hung a door in my life. That being said, I certainly am not afraid to try.
Anyway, we are in the process of closing off the library so my wife can use it as a home office. There was an existing open doorway between this room and our morning room that I have closed. Now I need to worry about the other end of the room...
There is another open doorway between a hallway and the library in which we would like to install double French doors. The following dimensions are with the ½ drywall still intact so I would gain +1 on the width and +.5 on the height : H = 95, W = 59.25, 8.25 D.
Adjusted dimensions: H = 95.5", W = 60.25", D = 8.25"
Question 1: When looking at doors at Lowes or HD, are the measurements for the entire framing of the door. In other words, if a door is listed as 60 x 80 does that mean that it will be exactly 60 across from edge to edge? As you can see, I dont have much room for error since the opening will be ~60.25 wide once I strip the drywall. If the actual size of the pre-hung door is a little larger than 60 (or 60.25 just wont cut it), I will more than likely move down to a 56 door and just pack it out.
Question 2: What do I do about that is 8.25 jamb since the door jamb will most likely be ~4.5? Do I install it on the edge of the jamb closest to the library since the door will open into it? If so, how much of an issue will I run into trying to trim out the remaining jamb? Is this even the proper method?
After all of that, am I getting in over my head? Should I just pay a professional to do it? If so, what kind of expense can I expect for the labor?
TIA!!!
JohnLast edited by johnodon; 02-07-12 at 05:56 AM.
02-07-12, 05:52 AM #2
- Join Date
- Feb 2006
- State:
- TN
- City:
- East Tennessee
- Posts
- 3,921
French Door
You say the present opening width is 50.25 in. If you remove the drywall, the adjusted width would be 51.25 in. What am I missing here?
02-07-12, 05:56 AM #3
- Join Date
- Jan 2012
- State:
- PA
- Posts
- 7
Crud...meant to say 59.25" so that would put the adjusted width at 60.25". I'll update the original post.
John
02-07-12, 06:04 AM #4
- Join Date
- Feb 2006
- State:
- TN
- City:
- East Tennessee
- Posts
- 3,921
Door Width
The sizes listed usually refer to the door sizes. In the case of French doors, the combined width of both doors. The package should give the required framed opening dimensions. The other option is to go to the store, slide one of the units out into the aisle and measure it. I think you will have to come down to the next size below 60 in.
02-07-12, 06:08 AM #5
- Join Date
- Jan 2012
- State:
- PA
- Posts
- 7
Thanks WP.
HD has a 56" Jeld-Wen that I would need to order online but at least it is an option.
Any comment about the extra-wide jamb?
Thx,
John
02-07-12, 06:11 AM #6
Another thing to consider...you'd probably need to special order anything other than a 5' or 4' door. I doubt anyone carries anything else in stock. Add about $150-200 to the stock price for a S/O. Might get lucky with an order that was wrong and is now in the mark-down bay.
EDIT: If you have to order, you might be better off seeing if they can do a jamb the thickness you need.Vic
"Vita brevis"
02-07-12, 06:15 AM #7
- Join Date
- Jan 2012
- State:
- PA
- Posts
- 7
I don't know if this is even a posibility...but could I replace the jamp on teh door myself with 8.25" stock? I never have seen one up close so I don't know how it is attached.
John
02-07-12, 06:27 AM #8
No, I wouldn't try to replace it. You can just build it out. Prob is, IIRC, interior door frames like that are about 5/8" frames. So 3/4" stock won't match exactly. You'd want to step it back from the frame slightly just like you would with casing on a regular door. You can do that by adjusting the rough opening width and height, shimming the door as needed, then attaching the extension stock directly to the studs or by shimming them out less than you did for the door.
Vic
"Vita brevis"
02-07-12, 06:30 AM #9
Like Vic said, if you are going to have to order the door anyway because it's special order, ask for the prehung door to come with an 8 1/4" jamb.
If they can't do it and you have to add a little trim to make it exactly 8 1/4", that can be done too, but why go to all that work when you can order it the way you want it???
02-07-12, 08:27 AM #10
- Join Date
- Jan 2012
- State:
- PA
- Posts
- 7
All great advice guys...I appreciate it. I think I have a clear path going forward.
Anyway, there is a carpenter right around the corner from us that others have used in our development and he comes highly recommended. I am going to have him come out to chat things over. Maybe I can get enough out of him to try it myself, or, maybe I just hire him (depending on price).
I'll check back in later and provide an update.
Thanks again!
John
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
