Login to DoItYourself
Forgot username or password?
Or Login with Facebook
Don't Have an account? Sign Up Today
do it yourself
  • How-Tos
  • Your Projects
  • Forums
search
Hi Unregistered | Logout Login Sign Up
  • Forum
    • New Posts
    • Today's Posts
    • FAQ
    • Calendar
    • Community
      • Member List
    • Forum Actions
      • Mark Forums Read
    • Quick Links
      • View Site Leaders
  • Advanced Search
  • Home
  • Forum
  • Interior Improvement Center
  • Insulation, Radiant and Vapor Barriers
  • Another basement insulation question
The Facebook Platform
Login | FAQ
+ Reply to Thread
Results 1 to 10 of 10
  • LinkBack
    • LinkBack URL LinkBack URL
    • About LinkBacks About LinkBacks
  • Thread Tools
    • Show Printable Version
  • Search Thread
      Advanced Search
  • Display
    • Switch to Hybrid Mode
    • Switch to Threaded Mode
  1. 11-15-05, 08:50 AM #1
    Craig_md
    Craig_md is offline Member
    Join Date
    Nov 2002
    Posts
    95
    Currently basement is completely unfinished. Walls are mostly below grade (except for the top foot or so) and uninsulated. The builder insulated between the floor joists of the first floor. After insulating the walls in the basement, is there any reason to leave the insulation between the floor joists? Was wondering if I could remove it and use it in the walls. Only drawback I could see is possibly it would help some with sound deadening through the ceiling/floor. Do most people just leave it there?
    Craig
  2. Sponsored Links
  3. 11-15-05, 10:35 AM #2
    chris8796
    chris8796 is offline Member
    Join Date
    Jun 2004
    State
    IL
    Posts
    385
    I personally would leave it (and would have added it if it wasn't already there), just for the sound control. You didn't mention your current climate control situation or future plans, which could further impact the decision.
  4. 11-15-05, 11:33 AM #3
    em69
    em69 is offline Member
    Join Date
    Jul 2005
    Posts
    857
    It will have a dramatic effect on reducing the sound transmission. I installed insulation in my basement before drywalling and it really helps.
  5. 11-15-05, 11:39 AM #4
    tlogan
    tlogan is offline Member
    Join Date
    Nov 2004
    State
    VA
    Posts
    272
    From what I've read on another forum dedicated to building home theaters, you DEFINATELY want to insulate between the floor joists.
    Tom
  6. 11-15-05, 01:02 PM #5
    Ed Imeduc's Avatar
    Ed Imeduc
    Ed Imeduc is offline Member
    Join Date
    Aug 2002
    State
    MO
    Posts
    18,389
    Wink
    A drop ceiling works real good for what you want. You can just lay that insulation on top of the drop ceiling. you can get back into it to work or change any wires around or work on the water pipes if you have to. Dont forget the insulation up on the sill platein the joist
    ED
  7. 11-21-05, 11:39 AM #6
    Konrad Fischer Visiting Guest
    Solid insulation will be best
    what belongs sound and thermal insulation. So I would recommend only solid materials as insulation like wood, gypsum cardboard, brick etc. depending of the situation referring dampness.
    Normal thermal insulation will 1st humidify in walls and 2nd not work against IR-Radiation transports, which will cause about 99% of thermal losses through constructions. I tested it out, you can see it here:
    www.xxxxxxxxxxxxxx-info.de/7mold.htm
    Good luck!
    Konrad
    >>>>Forum Monitors Notes:
    The thread has been edited.
    Advertisements within the forum topics or within replies posted or within personal signatures, personal web sites or including email addresses within replies or signatures is not allowed on this web site. Surveys, Ads, Advertisements, Solicitations to market products, services or to hire person(s) to perform work is also not allowed in any forum topics.
    Posting email addresses for others to contact to obtain information or to market products or directing anyone to personal web sites which can market products or solicit services, etc are not allowed. There Are No Exceptions.
    Members posting any of the above or similar, anywhere on the web site are doing so in violations to the policy and are subjected to suspension or banning.
    No topics are to be used for personal gain using any method. Allowing any of the above degrades the entire web site for all concerned parties.
    Read The Rules Here:
    http://forum.doityourself.com/announcement.php?f=2&announcementid=113
    http://forum.doityourself.com/announcement.php?f=2&announcementid=114
    Sincerely, Robert Horning.
    Web Site Administrator.
    Sharp Advice. Web Site Host, Forums Monitor & Multiple Topics Moderator.
    Last edited by Sharp Advice; 11-23-05 at 08:41 PM. Reason: No Ads, Advertisements Or Personal Web Sites Allowed
  8. 11-21-05, 07:35 PM #7
    Stevetra's Avatar
    Stevetra
    Stevetra is offline Member
    Join Date
    Sep 2004
    State
    NC
    Posts
    348
    I cantin understandin the German
  9. 11-22-05, 05:15 AM #8
    Thumbs up Oh, I am so sorry,
    but perhaps you can try again the just updated site. It is in 'my' english, some wrong terms and grammer are perhaps tolerable.
    Konrad Fischer
    Architect / Civil Engineer
  10. 11-22-05, 09:48 AM #9
    Concretemasonry's Avatar
    Concretemasonry
    Concretemasonry is offline Member
    Join Date
    Mar 2005
    State
    MN
    Posts
    6,073
    Konrad - I understand you comments and concept.
    Unfortunately, American construction, design and advertising is based on temporary, lightweight construction with lightweight materials that do well in the steady state hot box insulation tests, but do not perform as well in the real world with dynamic (not steady state) temperature and humidity fluctuations.
    Most of the rest of the developed world understands the concept, but Americans have a limited view because of the tradition of light construction. One part of the concept that is recognized is the need for thermal interia and heat storage in solar homes. The use of the concept is recognized by some designers and standards, but not by the general public. It will be a long time before the concepts become fully understood, since an R-value is easy to understand (and mis-use).
    Dick
  11. 11-23-05, 04:03 AM #10
    Thank you Dick
    but I know the american standards of lightweight building construction. We learn in university, we can see them in TV flying away through hurricanes and be transported on road and my cousin married an american carpenter from Boston. Besides in Germany the 'ecologic voodoo religion' promotes this lightweightery with all tricks as the last supper before temperature crash of the manmade heated world ;-)
    So I suggest to insulate only with solid wood - that may be due to the lightweighters, or? Look to my www.xxxxxxxxxxx-info.de/7mold.htm to get some idea of our 'Lichtenfelser Experiment', where we checked out the senseless R-value-champoins like fiberglass, polystyrene etc.
    Nevertheless, I know enough from completely molded cellulose and fiberglass and polystyrene insulation, also in spite of cellulose insulation is poisoned material (biozides). Never would I bring such pest in my house.
    Forum Monitors Note:
    Post edited. Link to personal web site removed and or edited.
    Second instance of a violation.
    Member has been suspended (6 months) for the rule and policy violation. Not suspended necessarily or solely for the information posted. Intitled to his/her opinion. Not allowed to use a personal web site regardless of the information it can offer. Read the rules.
    Sincerely, Robert Horning. Web Site Administrator.
    Sharp Advice. TCB4U2B2B Business Management Services.
    Personal Driving Safety Reminder:
    Buckle Up & Drive Safely.
    "The Life You Save, May Be Your Own."
+ Reply to Thread
« Previous Thread | Next Thread »
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
  • BB code is On
  • Smilies are On
  • [IMG] code is On
  • [VIDEO] code is On
  • HTML code is Off
  • Trackbacks are On
  • Pingbacks are On
  • Refbacks are On
Forum Rules
  • Newsletter Sign-Up
    Signup
  • Find a Professional
  • Follow @DoItYourselfcom
  • Related Ads
DoItYourself.com®, founded in 1995, is the leading independent home improvement and repair website. We welcome your comments and suggestions. All information is provided "AS IS." Website operating problems contact Webmaster. Questions of a Do It Yourself nature should be submitted to our "DoItYourself.com Community Forums". Copyright © 1995-2014 DoItYourself.com Inc. All rights reserved. You may freely link to this site, and use it for non-commercial use subject to our terms of use. View our Privacy Policy here.
RSS feed Advertise Find a Contractor Interactive How-to's About Us Terms of Use Privacy Policy Cookie Policy Site Map
DoItYourself.com is an INTERNET BRANDS company.
  • Contact Us
  • DoItYourself.com
  • Mobile Site
  • Privacy Statement
  • Top
Powered by vBulletin™ Version 4.2.2 Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
