Login to DoItYourself
Forgot username or password?
Or Login with Facebook
Don't Have an account? Sign Up Today
do it yourself
  • How-Tos
  • Your Projects
  • Forums
search
Hi Unregistered | Logout Login Sign Up
  • Forum
    • New Posts
    • Today's Posts
    • FAQ
    • Calendar
    • Community
      • Member List
    • Forum Actions
      • Mark Forums Read
    • Quick Links
      • View Site Leaders
  • Advanced Search
  • Home
  • Forum
  • Interior Improvement Center
  • Insulation, Radiant and Vapor Barriers
  • Black Insulation in Walls
The Facebook Platform
Login | FAQ
+ Reply to Thread
Results 1 to 6 of 6
  • LinkBack
    • LinkBack URL LinkBack URL
    • About LinkBacks About LinkBacks
  • Thread Tools
    • Show Printable Version
  • Search Thread
      Advanced Search
  • Display
    • Switch to Hybrid Mode
    • Switch to Threaded Mode
  1. 11-22-05, 10:59 AM #1
    indylola
    indylola is offline Member
    Join Date
    Jun 2005
    Posts
    18
    Ripping apart a wall in the bathoroom I found some insulation that is black. What does that mean? Has the insulation gone bad or is it just old?
    Thanks,
    Dean
  2. Sponsored Links
  3. 11-22-05, 12:21 PM #2
    Concretemasonry's Avatar
    Concretemasonry
    Concretemasonry is offline Member
    Join Date
    Mar 2005
    State
    MN
    Posts
    6,073
    It means you probably had moisture and mold in the wall.
    Find out why and replace it.
    Dick
  4. 11-22-05, 12:38 PM #3
    twelvepole
    twelvepole is offline Member
    Join Date
    Aug 2000
    State
    OH
    Posts
    15,834
    If insulation fibers appear to be naturally black, there is a black insulation. CertainTeed makes a black insulation for acoustical purposes.
  5. 11-22-05, 03:07 PM #4
    Concretemasonry
    Join Date
    Mar 2005
    State
    MN
    Posts
    6,073
    Also foam glass, but not too common in residential.
    Dick
  6. 11-27-05, 08:30 AM #5
    Konrad Fischer Visiting Guest
    Must be mold attack normally,
    because the lightweight insulation has no capillar activity, what means this materials will never dry out the condensate what must go into your bathroom wall, in spite of all vaporproofs, which will be moistured and moldy after some years as our experience proves. It is possible that allergy and asthma follows. Take it out carefully, and then do only solid wood boards in. They will work best as thermal insulationand can stand the condensate, because they do dry out.
    Besides the lightweight insulation is not able to stop IR radiation, which is responsible for about 99% of the thermal losses. Only solid materialslike wood and stone can stop thermal losses. The fairy tales about heat conductivity you should not believe in. They are told from insulation industries and their fellows. In the 'Lichtenfelser Experiment' we experienced the opposite reality.
  7. 11-30-05, 06:14 PM #6
    twelvepole
    Join Date
    Aug 2000
    State
    OH
    Posts
    15,834
    Because the bathroom is a room where moisture is common, a low permeability vapor barrier over insulation should be installed on the inside surface of the framing to avoid rot within the walls.
+ Reply to Thread
« Previous Thread | Next Thread »
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
  • BB code is On
  • Smilies are On
  • [IMG] code is On
  • [VIDEO] code is On
  • HTML code is Off
  • Trackbacks are On
  • Pingbacks are On
  • Refbacks are On
Forum Rules
  • Newsletter Sign-Up
    Signup
  • Find a Professional
  • Follow @DoItYourselfcom
  • Related Ads
DoItYourself.com®, founded in 1995, is the leading independent home improvement and repair website. We welcome your comments and suggestions. All information is provided "AS IS." Website operating problems contact Webmaster. Questions of a Do It Yourself nature should be submitted to our "DoItYourself.com Community Forums". Copyright © 1995-2014 DoItYourself.com Inc. All rights reserved. You may freely link to this site, and use it for non-commercial use subject to our terms of use. View our Privacy Policy here.
RSS feed Advertise Find a Contractor Interactive How-to's About Us Terms of Use Privacy Policy Cookie Policy Site Map
DoItYourself.com is an INTERNET BRANDS company.
  • Contact Us
  • DoItYourself.com
  • Mobile Site
  • Privacy Statement
  • Top
Powered by vBulletin™ Version 4.2.2 Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
