Login to DoItYourself
Forgot username or password?
Or Login with Facebook
Don't Have an account? Sign Up Today
do it yourself
  • How-Tos
  • Your Projects
  • Forums
search
Hi Unregistered | Logout Login Sign Up
  • Forum
    • New Posts
    • Today's Posts
    • FAQ
    • Calendar
    • Community
      • Member List
    • Forum Actions
      • Mark Forums Read
    • Quick Links
      • View Site Leaders
  • Advanced Search
  • Home
  • Forum
  • Interior Improvement Center
  • Insulation, Radiant and Vapor Barriers
  • attic insulated on roof rafters
The Facebook Platform
Login | FAQ
+ Reply to Thread
Results 1 to 2 of 2
  • LinkBack
    • LinkBack URL LinkBack URL
    • About LinkBacks About LinkBacks
  • Thread Tools
    • Show Printable Version
  • Search Thread
      Advanced Search
  • Display
    • Switch to Hybrid Mode
    • Switch to Threaded Mode
  1. 11-26-05, 11:02 AM #1
    max Visiting Guest
    Hello , I have a ranch syle home in Canada. It has a mix of cathedral ceilings and suspended steel drywall ceilings. The insulation is 3 inch paper backed fiberglass stapled to the roof rafters and down the cavities of the cathedral ceilings. The insulation has started to fall off some of the rafters as the paper has deteriorated. My question is can I add blown cellulose onto the suspended steel ceiling and down the cathedral cavities and simply leave the old paper back insulation where it is ? Any help would be great . thanks Max.
  2. Sponsored Links
  3. 11-27-05, 08:17 AM #2
    Konrad Fischer Visiting Guest
    Thumbs up Some remarks
    may be helpful:
    What we found out by testing (Lichtenfelser Experiment) in Germany and by comparing additional insulated appartement houses with the same houses in direct neighbourhood without any improvement ref. insulation:
    There is no insulating effect compared with solid materials like wood and brick.
    Googling for Lichtenfelser Experiment you can find a pic with a figure of our test, where we had only 10 min IR radiation from a redlight bulb on different insulation materials each 4 cm (From above in opposite ranking: Fiberglass, Styrofoam, Foamglass, Brick, Wood fiber board, gypsum card board, solid pinewood). The temperatures are measured on the back of the boards, fiberglass had 40 degrees increasing, solid wood none!
    Besides the lightweight insulation has no capillar activity, what means this materials will never dry out the condensate what must go in, in spite of all vaporproofs, which will be moistured and moldy after some years as our experience shows. I do measure this with my equipement so often in my building consultations all around Germany.
    So I recommend not to crumble some lightweight insulation in your construction, instead take solid wood boards if you must have a additional thermal insulation f.e. in attics. About 6-8 cm would be good. If you have a masonry orsolid wood wall, no additional insulation is necessary at all. In summer cool, in winter warm, thats the effect of solid material enveloping the rooms.
    Some explanations ref. radiation and heat conductivity:
    The problem is the way to measure the R-value. Not many in building branche
    knows how this is done. Warm air is ventilated to the proof material, cools off and is warmed again outside the 'proof box'. The amount of energy to rewarm is the base for the R-value. It tells only something about cooling of warm molecules on colder surface molecules of the test material.
    But: Does the cooling of your hand on a steel plate and a carpet in your room with both room temperature say anything about the wandering of IR radiation through the materials?
    Will sunlight - also an electromagnetical radiation - shine through an 1 cm board of styrofoam? And wood? So you can see what works best against IR
    radiation. And it is IR radiation, what is reasonable for about 99% of temperature losses through material, believe it or not.
    And what is going on in a heated room? In a 20 sqm room there are about 60 kgs heated air giving energy in the facade wall, but about 5-10 tons of IR-radiating wall surfaces, the radiation is nearly on the level of air temperature, you can measure it at the wall by IR-thermometer. So about 99% of the heat transport through materials is radiation (by photones/phonones).
    So lightweighters in the building construction are a really pest and only a fake and hoax of 'our' industries and their obscene slaves in science and administration! They damage buildings, invests and - most important - make persons ill with asthma, allergy etc. Even in cellulose insulation is found mold after some time, in spite of all the poison (borates) they give in against it.
    Thats the thing: No lightweighters as thermal insulation in and on the walls, in attics, under floors, in the foundations and so on. There is only one good purpose for those - as carpets, to keep the feet warm. Because the molecular contacts are fewer than the marbles on the floor can offer to the warm feet. And so there will be fewer thermal losses by direct molecular contacts. Inspite they have the same room temperature. You can prove that also by measuring with an simple IR thermometer.
    Surprising? But true. And well known in earlier centuries from all building experts.
    Look on the good old buildings. Modern craftsmanship and engineering is the biggest danger for them, isn't it?
    Good luck!
    Konrad
+ Reply to Thread
« Previous Thread | Next Thread »
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
  • BB code is On
  • Smilies are On
  • [IMG] code is On
  • [VIDEO] code is On
  • HTML code is Off
  • Trackbacks are On
  • Pingbacks are On
  • Refbacks are On
Forum Rules
  • Newsletter Sign-Up
    Signup
  • Find a Professional
  • Follow @DoItYourselfcom
  • Related Ads
DoItYourself.com®, founded in 1995, is the leading independent home improvement and repair website. We welcome your comments and suggestions. All information is provided "AS IS." Website operating problems contact Webmaster. Questions of a Do It Yourself nature should be submitted to our "DoItYourself.com Community Forums". Copyright © 1995-2014 DoItYourself.com Inc. All rights reserved. You may freely link to this site, and use it for non-commercial use subject to our terms of use. View our Privacy Policy here.
RSS feed Advertise Find a Contractor Interactive How-to's About Us Terms of Use Privacy Policy Cookie Policy Site Map
DoItYourself.com is an INTERNET BRANDS company.
  • Contact Us
  • DoItYourself.com
  • Mobile Site
  • Privacy Statement
  • Top
Powered by vBulletin™ Version 4.2.2 Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
