replacing 2 gang 1 way dimmer with 2 gang 2 way switch
08-05-08, 11:56 AM #1
- Join Date
- Aug 2008
- Posts
- 1
Help.
Have 2 lights that did work independently off same 2 gang 1way dimmer switch. Need to replace switch with 2 gang 2 way.
Cable1 has Red + Blue + earth & cable 2 has red + Black + Yellow + earth. Blue & black were joined via a connector. Earths were both grounded.
Dimmer connection was red from cable 1 to C (bridged to both boxes). Yellow cable 2 went to box 1 L1. Red cable 2 went to box 2 L1.
New switch has C + L1 + L2 (again 2 boxes). Where should I put the wires?
08-05-08, 04:11 PM #2
- Join Date
- Mar 2006
- State:
- WI
- City:
- Appleton/ Paris
- Posts
- 4,807
I am sure this is UK system.,,
So bear with me a min to get this straght.,,
you have one with dimmer { one way } and one reguair switch point { one way } ?
and you want to change over to 2 way ? for both luminaires ?
Both luminaire indepent { each it own switch }??
I am pretty sure the cable two is old style cable while the cable one is newer one due the colour code.
let us know then we can go from there.
{ Is any chance can you run the dimmer model number to make sure thanks }
Merci,Marc
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
