Need help with GFCI outlet with switch wiring
I'm replacing regular outlet/switch in bathroom with GFCI. Currently there are 3 conductors, (red, white, and black). Switch operates bathroom light.
I need help with wiring. Pictures attached
Can someone please help me with wiring?
Thanks
Thanks
If the house black wire is connected to the side of the original device that has a tab and that tab has not been removed the wiring is:
The above isolates the light from the GFCI function so that if the GFCI trips the light remains on.
*Some GFCIs will accept two wires. If that is the case pigtailing is optional.
- One black wire of the new switch and house black pigtailed to the line side of the GFCI*.
- Other black wire of the new switch to house red wire.
- White house wire to silver screw line side of new switch.
