Re-securing T-top to deck
06-22-08, 08:09 AM #1
- Join Date
- Jun 2008
- State:
- FL
- Posts
- 1
The T-top on my 20 foot Pro-liner is extremely loose. Two of the four screws in each of the front feet to secure to deck just pulled right out. We went 25 miles out in the Gulf last week and I had to tie down the top with the bow line from the top for fear of loosing it as we where running through 2/3 foot seas. What type of screw can i use that will "spread" below deck, as the hole has worn too large just to use a larger screw? Or any other process known. thanks
06-24-08, 11:51 AM #2
- Join Date
- Aug 2005
- Posts
- 2,251
Are you trying to screw into a wooden portion of the boat - or metal trimwork?
06-24-08, 09:40 PM #3
- Join Date
- Jun 2008
- State:
- WA
- City:
- vancouver
- Posts
- 2
fastening options
general options for worn out/ stripped out holes. If you have access to interior space i suggest using a 1/4 to 1/2 aluminum plate slightly larger than the mounting base. put it up to the mounting plate, mark holes and drill and tap for stainless screws of appropriate size. then with a helper to hold it in place ( below deck) re attach your mounting base. it will be stronger than new.
If u dont have access, u may try and find some toggle style fasteners. this will require a larger hole than is there, and you will need to make sure u have a rubber gasket to seal or use a marine approved caulk to seal to prevent damage to the interior of your boat.
hope this is helpfull
Luke
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
