2007 Titan scooter kills when braking
02-11-12, 08:11 AM #1
- Join Date
- May 2008
- State:
- MN
- City:
- Brainerd
- Posts
- 58
I have a 2007 Titan scooter that will start fine on the stand so that the back wheel is spinning, but if you apply the rear brake and slow down the rpms, the engine kills. The idle speed is set quite high so I dont think its that. Any ideas whats wrong?
02-11-12, 08:36 AM #2
I will assume that the clutch is automatic.
It most likely is that the idle is set too fast.
An automatic clutch will begin to engage above a certain rpm and yours likely is doing just that.
You would either have to experiment by lowering the idle speed until it idles without engaging or get the specs and use a tachometer to set it.
or, the clutch is seized and needs to be repaired or replaced.GregH...HVAC/R Tech
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
