Need help
02-16-12, 10:02 AM #1
- Join Date
- Feb 2012
- State:
- CANADA
- City:
- Mississauga
- Posts
- 1
Need help
I have 96 yamaha big bear the rear end/final drive was ran dry
Should I just put oil in or what?
One more? Atv will not run unless choke is on
Pls let me know need this thing working
Thanks phc
02-25-12, 07:16 AM #2
- Join Date
- May 2006
- State:
- IA
- City:
- Da Moines
- Posts
- 2,435
It would be a gear lube or hypo grease not just oil. Put in the manufacturer recommended. Then you have to figure out where the lube went. If it has a seal out of it, that will have to be fixed.
As far as it just running on the choke - first try some Sea Foam added to the gasoline. You can get that from an auto parts store. It just has some carb blockages. A lot of times the Sea Foam will clean it up and you won't have to disassemble it.
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
