Repair or replace Craftsman leaf blower 358.797290
JIMMIEM's Avatar
MA
07-14-16, 04:40 AM   #1 (permalink)
My Craftsman Leaf Blower was working but now will not start. I put in a new spark plug. Should I keep going with trying to repair it or just buy a new one? A new carb is $30 - $40...that's the most expensive component.
Wirepuller38's Avatar
TN
07-14-16, 05:22 AM   #2 (permalink)
Blower
How old is the blower?
What type of fuel do you use?
What have you done to repair other than a new spark plug?
Geochurchi's Avatar
NH
07-14-16, 05:30 AM   #3 (permalink)
Do you have a good spark?if have you checked the fuel filter? if it's not running take the carb apart and rebuild it about $15 for a kit,my theory is,if it's not working now you can't make it any worst and you may learn something.
joecaption's Avatar
VA
07-14-16, 06:04 AM   #4 (permalink)
Checked the fuel filter inside the tank?
Checked for spark?
Checked on Amazon for that part?
Poulan makes the trimmers for Sears.
Part #545081882
Been running ethanol fuel in it?
You'll have far less issues with all your 2 cycle power tools if you used non ethanol fuel and only mixed 1 gal. at a time.
At least 90% of the time on those small engines it's going to be a fuel related issue.
Ethanol destroys the fuel lines and gums up the whole inside of those tiny carburetors.
beelzebob's Avatar
CT
07-14-16, 06:21 AM   #5 (permalink)
You are asking a question that need many more inputs to give good advice. Assuming the blower was working properly before you changed the spark plug, there are not many things that can go wrong. You only need spark and gas.
If you ground the spark plug outside the engine and pull the start rope, do you get a good spark? If not, remove the wire from the ON/OFF switch and try again. If no spark, follow wire from ON/OFF switch to ignition module and verify it is not shorting to ground anywhere. If not, the ignition module is suspect and should be taken to a repair shop and tested. Replace if bad.
Once you have spark, you can consider carb problems. Most likely is a dirty filter in the tank or an obstruction in a carb passage. The filter can be replaced. The carb must be disassembled to clean the passages.
Good luck.
geogrubb's Avatar
MO
07-14-16, 07:19 AM   #6 (permalink)
Those blowers have a tendency for the head bolts to get loose, tighten them. Check the compression if below 100 you have problems. Remove the muffler and check the piston and cylinder wall for deep scratches an gouges, if you find the it is shot. Have a good one. Geo
cheese's Avatar
GA
07-14-16, 10:33 AM   #7 (permalink)
Geogrubb hit the point I was about to make in my reply.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
BFHFixit's Avatar
KS
07-14-16, 11:29 AM   #8 (permalink)
If you are mechanical and patient it can be fixed usually for not much in parts.
Those units are tedious PIA to work on even just replacing the fuel lines requires the entire disassembly.
IMO they are not that good of a machine. Anything that requires more steps to start than it takes to fly a plane, can't be good.
Just needs a bigger hammer
Peace
JIMMIEM's Avatar
MA
07-21-16, 10:30 AM   #9 (permalink)
Today I opened it up and sprayed some GUMOUT into the carburetor. It started and ran for about 15 seconds before stopping. I sprayed more GUMOUT. Again it started and ran for the same length of time. Is it running on the GUMOUT? Clogged fuel filter maybe?
Carburetor didn't look gunked up. There are some leaks on the outside of the machine. Maybe replace gaskets? Would these be included in the carb rebuild kit?
cheese's Avatar
GA
07-21-16, 11:17 AM   #10 (permalink)
Did you take the carb apart and look? You can't tell if the carb needs cleaning or not from the outside.
God bless!
JIMMIEM's Avatar
MA
07-21-16, 12:09 PM   #11 (permalink)
I took most of it apart...primer bulb, gaskets. What should I be looking for?
cheese's Avatar
GA
07-21-16, 04:52 PM   #12 (permalink)
Usually trash clogged in the inlet screen among other places.
God bless!
JIMMIEM's Avatar
MA
07-23-16, 01:07 PM   #13 (permalink)
Where should I buy parts from? Filters, lines, maybe a carburetor.
I don't have SEARS parts center nearby so I'll have to buy online. SEARS sells online but I have found them to be pricey....although not talking big $ here.
