vibration whenn accelerating 93 Ford Escort
Jack5's Avatar
12-16-09, 10:18 PM   #1 (permalink)
Hi,
I have a 93 1.9 litre, automatic Ford Escort, recently inspected. It has new tires. When you go above 38 mph the car vibrates badly. It is like a washing machine on spin cycle. It mostly does this during acceleration. Motors mounts were checked by five guy friends, they said were fine. Someone suggested Ujoints.
Any ideas? I want this taken care of before it does damage to car. I've had the car since June/July and it has done it since then. Any help is appreciated. Thank you.
marbobj's Avatar
IA
12-17-09, 06:01 AM   #2 (permalink)
If the engine is running well - CV joints/half shafts probably. Could be something in the tranny, but the shafts would be a better guess.
Sharp Advice's Avatar
Admin, Forums Host & Manager
CAL
12-17-09, 08:20 AM   #3 (permalink)
Another possible cause may be a front end out of in linement. An excessive rear ward caster will cause front end shimmy on acceleration when front end is lightened up. Can and may happen at any speed. Unsafe condition that needs to be corrected (IMO) asap.
hopkinsr2's Avatar
Non-US
12-17-09, 05:52 PM   #4 (permalink)
You have problems since June or July & only asking about it now??? I'm sure any damage that would happen would have happened by now,, But I agree with Marbobj about the CV joints,, They wear & cause vibration as you have.... Roger
the_tow_guy's Avatar
FL
12-17-09, 07:45 PM   #5 (permalink)
Same symptoms my wife's Camry had when the CVs wore out; shook like crazy when you hit the gas going up a freeway on-ramp.
Measure it with a micrometer; cut it with an ax.
Jack5's Avatar
12-19-09, 02:36 PM   #6 (permalink)
Hi all,
Thanks for all who replied. The vibration wasn't as noticeable when I first got the car, thus didn't fix it. The boot is bad on the passengers side front tire. It might also need aligned. Thanks to all who replied. Plan to diagnose and fix asap. If you have any other suggestions, I would appreciate it. Thanks
marbobj's Avatar
IA
12-19-09, 02:59 PM   #7 (permalink)
You're talking about the CV boot? If that's the case a CV joint normally only has a one month life without the boot in good shape.
