ABS sensitivity adjustment?
donoli2016's Avatar
01-10-17, 02:01 PM   #1 (permalink)
2000 Chevy Express
Is there a way to adjust the anti lock braking sensitivity? If there is snow on the ground, my anti lock brakes won't let me stop. The pedal pulsates causing the vehicle to slide through a stop sign.
I'm ready to remove the relay or fuse. However, I wanted to ask if there is a sensitivity adjustment before I remove the relay or fuse.
Pilot Dane's Avatar
NC
01-10-17, 02:06 PM   #2 (permalink)
It sounds like they are doing what they should. If you are on ice or slippery snow no change in ABS is going to make much difference. ABS just helps keep you pointing forward.
Marq1's Avatar
MI
01-10-17, 03:40 PM   #3 (permalink)
There is no adjustability in the ABS.
However, if you van is lightly loaded that may be making it sensitive to wheel lock up so some weight in the back will help.
ukrbyk's Avatar
WA
01-10-17, 03:41 PM   #4 (permalink)
OP, ABS is doing its job. There is reason it will not allow you to LOCK the wheels. Instead of adjusting ABS or disabling it, you simply need to adjust your braking distance and plan ahead.
DO NOT disable ABS. Please.
Gunguy45's Avatar
Super Moderator
AZ
01-10-17, 05:29 PM   #5 (permalink)
Exactly the issue I had with a Dodge Dakota with rear ABS only. Unloaded, even a relatively hard stop (not panic or in snow) would have the rear end jumping up and down. Chirp, chirp, chirp!
Your van is probably 4 wheel ABS, and though it may feel odd, ABS helps with braking in slippery conditions (assuming appropriate tires, slicks will slide no matter what).
As ukrbyk said, anticipate and adjust your braking distance. No matter what, if there's black ice in the stopping area, you'll probably slide right through unless you've given yourself the extra room.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
donoli2016's Avatar
01-11-17, 05:56 AM   #6 (permalink)
The weight thing makes the most sense so far. I have 4 or 5 five gallon buckets loaded with tools along with other things.
As far as my braking distance goes, I couldn't have gone any more slowly or braked any earlier than I did yesterday. The only way I can brake sooner is if I don't step on the gas in the first place.
donoli2016's Avatar
02-09-17, 01:28 PM   #7 (permalink)
It's snowing again & it's time to disable ABS. I see 2 fuses, inside the van. One is marked brake & one is marked stop. Is stop the stop lights & brake the ABS? I didn't look under the hood yet at the cube relays.
2000 Chevy Express 1/2 ton 1500
NJ
02-09-17, 01:59 PM   #8 (permalink)
Underdash fuse box..............
1. STOP - CHMSL(3rd brake light), Stoplamps
18. BRAKE - 4WAL PCM, ABS, Cruise Control
Underhood fuse box.......
Not supplying any comments. Just supplying what you asked for.
My guess would be #18 only.
~ Pete ~
donoli2016's Avatar
02-10-17, 04:29 PM   #9 (permalink)
Thanks PJ. I removed the fuse marked Brake & all was well.
