Replacing a GM fuel pump
I'm replacing a fuel pump on a 1986 GM 454. It's in a boat, but that doesn't really matter, except it's even more cramped and they get to charge you more because it's a "marine" application. Anyway, does anyone know a trick for keeping the pushrod up and out of the way long enough to put the fuel pump in place? I've tried removing it and wiping it down to increase the friction, but that didn't help.
If it is anything like a 350 there is a bolt in the front of the block by the edge of the motor where the pushrod is. Remove this bolt and replace it with a longer one. The new longer one will press against the side of the push rod and hold it up. Only thighten it enough to so the rod doesn't slip back down. When the new pump is in place remove the longer bolt and reinstall the short one again so nothing is rubbing the push rod and no oil leaks out the front.
Hope that helps,
Byam
Hope that helps,
Byam
Originally Posted by Byam
Wouldn't the grease end up in the oil pump and/or filter? Or is that not a problem?
Byam
Byam
