2007 Toyota Camry heating problem
01-17-12, 10:07 AM #1
- Join Date
- Jan 2012
- State:
- NY
- City:
- Central Square
- Posts
- 3
I have a 2007 Toyota Camry with eratic heating. When I use my car starter to start my car to let it warm up the heat works just fine! But when I turn the key on and drive the car the blower blows cold air. But if I go above 30 the heat will start to come back. If the car is running in park there is no heat just blowing cold air! I hope some one can help! The faster the car goes the quicker the heat will return!
01-17-12, 06:18 PM #2
2007 you say? let me show you some pictures:
and this one just to tease you:
basically, I have 2.4L 07 Camry engine, paired with hybrid drive. Water pumps in those go bad around 50 000 miles. some sort of bad design flaw. look for signs of coolant , like you see on pics.
you go faster - RPMs go up - coolant circulation improves - more heat. BAD PUMP.
yes, that's home smoked chicken and salmon caviar.
01-18-12, 06:26 AM #3
- Join Date
- Jan 2012
- State:
- NY
- City:
- Central Square
- Posts
- 3
Thanks for the help I will take a look after work today!
01-20-12, 09:52 AM #4
- Join Date
- Jan 2012
- State:
- NY
- City:
- Central Square
- Posts
- 3
I took a closer look yesterday and it turns out the water pump is bad! thanks for your help!!
02-08-12, 07:44 PM #5
yeahhh.. membering in 3 Toyota forums, it's quite noticeable they had real chitty design for the year and few after.
they even came up with electrical pump for 2012 hybrids.
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
