How to repair a gap between ceiling and wall
What is the best way to repair a gap between a wall and ceiling? I have about a 1 in gap between the wall and ceilng over a door in an upstairs hallway and about the same in on of the corners.
Welcome to the forums! Pictures may help, but sight unseen, installing sheetrock on the top plate which should be exposed, then applying tape and mud, sanding and painting. http://www.doityourself.com/forum/el...your-post.html
A 1" gap is pretty wide, any idea what caused it? 1" is also kind of thin for a piece of drywall. You might be better off taking some setting compound like durabond and prefilling the gap [doesn't need to be perfect but make sure the durabond is in the void and not hanging out] and then taping it once the filler has dried.
