1999 chevy security light blinks,engine won't stay running
02-16-12, 11:04 AM #1
- Join Date
- Dec 2008
- State:
- MS
- City:
- meridian
- Posts
- 3
someone told us to leave the key on till the light stopped blinking,we did and it ran....then did it again. cranks up runs 5 or so sec dies. did the key thing on again, ran now won't reset.
02-16-12, 11:28 AM #2
What kind of Chevy? Possibly a fuel shut off.
There are several fixes if so.
Mike NJ
02-16-12, 12:15 PM #3
- Join Date
- Dec 2008
- State:
- MS
- City:
- meridian
- Posts
- 3
it is a 1999 chevy pick-up, dually with a 454 engine.we un hooked the battery, it does not show an engine code
02-16-12, 12:59 PM #4
OK look in your manual if you have one. Find a section that says passlock. I think that vehicle has one. Its a hall effect sensor in the ignition.
To reset I believe you need to leave the ignition on for 10 minutes until the light goes out.
Although I had trouble with mine I sprayed the key and ignition cylinder with lubricant and I gt another yr or so befor it acted up again.
First we need to determin if thats your issue.
security light still flashing right?
I ended up soldering a resistor in line with the control modual. There are other ways by disconnecting the wire to it but the security light will stay on all the time. I did not want that.
I will try to find the link and post back.
let us know what the manual says. Should be under "passlock" " fuel" etc....
Mike NJ
02-16-12, 01:32 PM #5
- Join Date
- Dec 2008
- State:
- MS
- City:
- meridian
- Posts
- 3
i will check on the manual tomorrow.just might need to spray it,we use it to "pack" the track at [link removed], it is a dirt track and a lot of mud and dust. we don't care it the light stays on if it is a quick fix. thanks Mike NJ
02-16-12, 06:44 PM #6
- Join Date
- Mar 2009
- State:
- TX
- City:
- Dallas
- Posts
- 934
Passlock issues are extremely common with older GM products to the point that GM included such 10 minute wait solutions in their owner manuals, but inspite of that, do you have a second key? Did you try using a second key to confirm the issue is also not with the key itself. That also does happen as keys get older. Keys can and do fail too.
03-05-12, 08:38 AM #7
- Join Date
- Jan 2007
- State:
- IN
- City:
- Idaville
- Posts
- 596
My car did some what the same thing but it wouldn't crank. I washed the key with dish soap and a tooth brush and fixed it.
| Sponsored Links |
LinkBack URL
About LinkBacks
Questions of a Do It Yourself nature should be submitted to our
